Hello
With dscp rewrite disabled, If you mark on dscp and dont trust on the interface, The dscp value with be kept, however is you trust on cos it will refer to the default mls qos dscp-cos map.
With dscp rewrite enabled - dscp/cos will be marked down to 0 unless trusted
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
