- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-14-2013 09:30 PM - edited 03-04-2019 07:53 PM
After reading about the OSPF packet types i am having some doubts,
1. What is the difference between DD,LSRequest,LSUpdate,LSAck packets and Router LSA
2. Instead of using the above four packets may i use only router LSA packets because it will send the update to all neighbors
3.Initially for making adjacency with the neighbors the four(DD,LSR,LSU,LSA) packets are used ,anyother purpose
Thanks in advance
Solved! Go to Solution.
- Labels:
Routing Protocols
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-15-2013 02:16 AM
there is no Router LSA packet. Router LSA is a LSA type (type-1) that travels inside a packet (LS Update packet).
Regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-15-2013 02:48 AM
each LSA have a LS age field. If this timer arrives to 60 min the LSA is delete. So each LSA have to be refresh by
its advertisement router before this timer expired. LSRefreshtime refers how often a router refresh the LSA's that
are originated by itself.
The other timers is to avoid traffic flooding. A router, after generating a LSA, must wait MinLSInterval to generate the
same LSA. And a route drop the received LSA if the same LSA was received in the last MinLSArrival seconds.
Regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-15-2013 12:33 AM
OSPF is a little complicated. First of all, you need the LSA concept. I do not know if you have managed some SQL
database. There is a table a each table has entries. An entry is defined by fields. Fields storages information and
are numerical, boolean and so on. Ok. The SQL table is the LSDB. An LSA is an entry in the table. An LSA have
fields: LS ID, LS Age, LSA Type, Advertisement Router, LS Sequence number and so on.
The main objetive in OSPF is that all routers in the same area have the same LSDB, they must be syncronized.
So, OSPF Packets Type are:
Hello Packets. Discovers neighbors and builds adjacencies between them.
Database Despcription Packets(BDB). It includes only a LSA header. It is not include all fields about the LSA. Only
some fields (as LS sequence number LS checksum) that let know if the LSA has change. A BDB is also multicast.
by a Link-State ACK packet.
Link-state request (LSR) Packet. If a router receive a BDB packet from a neighbor and have older information about the LSA, the it sends a LSR to receive all fields about the LSA.
LSUpdate packet. A router that receives a LSR send LSUpdate with all information about the LSA request. A LSUpdate must be ACK by a LS Ack packet.
LS ACK. It only a packet to ACK other packets (LS Updates).
So, now your questions:
1- You are mistaken Router LSA is not a packet type. It is a type of LSA.
2- Yoy need all types of packets.
3- Only Hello packets.
Regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-15-2013 02:02 AM
Thank you
The below lines i referred from RFC 2328
LSRefreshTime
The maximum time between distinct originations of any particular
LSA. If the LS age field of one of the router’s self-originated
LSAs reaches the value LSRefreshTime, a new instance of the LSA
is originated, even though the contents of the LSA (apart from
the LSA header) will be the same. The value of LSRefreshTime is
set to 30 minutes.
MinLSInterval
The minimum time between distinct originations of any particular
LSA. The value of MinLSInterval is set to 5 seconds.
After reading this only i thought Router LSA also one packet it will be transmitted periodically
Router LSA is a packet or just one entry in LSDB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-15-2013 02:16 AM
Regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-15-2013 02:29 AM
Thank you so much
Finally what is the use of LSRefreshtime - 30 minutes, MinLSInterval - 5 seconds, MinLSArrival - 1 second and Maxage - 1 hour (RFC 2328)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-15-2013 02:48 AM
Regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-15-2013 03:18 AM
what is the interval for sending database description packet
My assumption is if LSRefresh is expired means start to send database description packets after that LSR, LSU then LSA
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-15-2013 02:02 AM
OSPF has five Message types
Every OSPF Messages have some function. When neighborship is forming first time or exchanging routes
1. Hello - Used to discover neighbors, supply information used to confirm two routers should be allowed to become neighbors (for example hello packet consists: Hello interval, dead interval, authentication, area ....), for becoming neighbor two routers must have the same parametrs.
And to monitor a neighbor's responsiveness in case it fails.
2. DD - Database Description Used to exchange brief version of each LSA, typical on initial topology exchage, so that a router knows a list of that neighbor's known LSAs
3. Link State Request(LSR) - A packest is used to request LSA from neighbor who has information about requested LSA
4. Link State Update (LSU) - A packet that contains fully detailed LSAs, typically sent in response to an LSR message
5. Link-State Acknowledgment (LSAck) - Sent to confirm receipt of an LSU, LSR, message. I think only hello packet is not reliable.
From the above briefly: When two routers enabled OSPF Protocol first the exchange Hello Packest, Hello packest consists some parametrs that must match to become a neighbor (Parametrs: area, authentication, Hello dead interval...). Next Routers exchange DD briefly two routers send brief information about networks thats it knows.
Received DD message router, compare information in DD with his own. If neighbor router has a new route. Router sends LSR. LSR message requests a new route from a neighbor. Then Neighbor advertise this route with LSU. Remember LSU may contain many LSAs.
I am not native english )
Hope this was helpfull
