[CBWFQ - Insufficient bandwidth]
wernerleg1
I'm unable to apply the service-policy to the interface with the config below.
majormatic-pta-mount(config-if)#service-policy output CE-OUTPUT
Insufficient bandwidth 1024 kbps for the bandwidth guarantee (512)
majormatic-pta-mountgrace-mi-ce#sh controllers Serial0/1/0
Interface Serial0/1/0
Hardware is GT96K
DTE V.11 (X.21) TX and RX clocks detected.
interface Serial0/1/0
description Link to xxxx
bandwidth 1024
ip address x.x.x.x
ip access-group 101 in
ip access-group 101 out
no ip redirects
no ip proxy-arp
ip flow ingress
no ip mroute-cache
load-interval 30
down-when-looped
no cdp enable
max-reserved-bandwidth 100
end
policy-map CE-OUTPUT
class CE-OUTPUT-PLATINUM
    bandwidth 256
     random-detect dscp-based
class CE-OUTPUT-GOLD
    bandwidth 256
class CE-OUTPUT-SILVER
    bandwidth 512
Werner
royalblues
Level 10
Level 10
I think you will have to leave a minimum of 64k for the default class even though it is not defined
So you will have to redo the bandwidth allocations so that you leave atleast 64k for the default BW class something like
    bandwidth 192
    bandwidth 256
    bandwidth 512
Try this and let us know
Narayan
Hi Narayan
I'm able to apply the same config on a different 2801 routers, looks like it's IOS dependant.
Example:
interface Serial0/3/0
bandwidth 256
ip address x.x.x.x.
no ip redirects
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
load-interval 30
down-when-looped
no cdp enable
end
  bandwidth 64
  bandwidth 64
  bandwidth 128
I had a look at the output of sh policy-map interface x
Router that requires extra 64K for default-class:
Class-map: class-default (match-any)
      787 packets, 94518 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: any
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 787/51931
Router that doesn't require extra 64K for default-class:
      2000 packets, 112873 bytes
      Match: any
Thanks for your help!
Werner
Hi Werner,
I think that's because of one of the router is running HQF model. With HQF model, class-default has minimal 1% of interface bandwidth; before HQF, class-default doesn't have pre-assigned bandwidth. The IOS starts using HQF model from 12.4(20)T. Also the 64 is queue limit, or you can consider it is the depth of this queue.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6558/white_paper_c11-481499.html
HTH,
Lei Tian
Thank you Lei..The linked helped me trouble shoot an issue with my customer after we did an IOS upgrade from pre- HQF version to 12.4(24) version.
