Cellular Data Profile is stuck on INACTIVE on Cisco ISR 4221
Dunner1991
We have recently decided to create an OOB management solution using a 4g SIM with Public IP
However we ran into issues where Public IP was not pingable and we could not ping the internet.
After a reboot the Public IP is reachable but now the LTE profile is in INACTIVE stateCellular Profile InactiveCellular Profile InactiveAPN
I have recreated the profile and re-attached it to the slot the IM is in (SLOT 0) but there is no change.
Does anyone have any ideas?
28 Replies 28
Hi @Georg Pauwen
I deleted the profile 2 with the following comands
no lte sim data-profile 2 attach-profile 2 slot 0
no profile id 2 apn JTFIXEDPUBLIC authentication none pdn-type ipv4
This was the output after deletion
dub1-00-oob-wgw1#show cellular 0/1/0 profile
Profile password Encryption level =  7
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = XXXXXXXXX
Authentication = None
  * - Default profile
 ** - LTE attach profile
Configured default profile for active SIM 0 is profile 1.
I then re-added the profile
This is the output after profile 2 was recreated:
dub1-00-oob-wgw1#show cellular 0/1/0 profile 2
Profile 2 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = JTFIXEDPUBLIC
 * - Default profile
PDP Type = IPv4
Access Point Name (APN) = XXXXXXXXXXXX
PDP Type = IPv4
  * - Default profile
Configured default profile for active SIM 0 is profile 2.
just to be sure the signal is strong enough, issue the command:
show cellular 0/1/0 all
and check for the section 'Radio Information' and a line similar to the one below:
Current RSSI = -125 dBm
What is the RSSI value ? Anything lower than 125 could mean either no antenna, or bad antenna or out of network.
try and put 'enacpsulation ppp' on the cellular interface:
interface Cellular0/1/0
bandwidth 2000000
ip unnumbered Loopback1
--> encapsulation ppp
ip nat outside
dialer in-band
dialer idle-timeout 0
dialer-group 1
pulse-time 1
HI @Georg Pauwen
This is the output from
show cellular 0/1/0 all | in RSSI
dub1-00-oob-wgw1#show cellular 0/1/0 all | in RSSI
Current RSSI = -52 dBm
So with this reading from the device, I am to assume that the network is not strong enough?
that value (-52) is within the acceptable range...
Hi @Georg Pauwen
Thank you for clarifying.
Also i have added the following to my config as per your suggestions i.e.
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
ip nat outside under the loopback 1 interface
encapsulation ppp was added under interface cellular 0/1/0 but does not show
dub1-00-oob-wgw1#show run int cellular 0/1/0
Building configuration...
Current configuration : 160 bytes
bandwidth 2000000
ip nat outside
dialer in-band
dialer-group 1
pulse-time 1
end
But the profile 2 will not become Active and as a result I can't ping to the internet
Mark
try a dialer in combination with the cellular interface. The configuration would look like below (important parts marked in bold):
! Last configuration change at 10:52:50 UTC Wed May 13 2020 by net_admin
version 16.11
service password-encryption
service call-home
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname dub1-00-oob-wgw1
boot-start-marker
boot system flash bootflash:isr4200-universalk9_ias.16.11.01a.SPA.bin
boot-end-marker
enable secret XXXXXXXXXXXXX
enable password XXXXXXXXXXXXX
no aaa new-model
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
no destination transport-method email
ip domain name cubictelecom.com
login on-success log
subscriber templating
crypto pki trustpoint SLA-TrustPoint
enrollment terminal
revocation-check crl
crypto pki trustpoint TP-self-signed-691021271
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-691021271
revocation-check none
rsakeypair TP-self-signed-691021271
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
XXXXXXXXXXXXXXXXXXXXX
license udi pid ISR4221/K9 sn XXXXXXX
license smart url default
license smart transport smart
license smart privacy hostname
license smart privacy version
diagnostic bootup level minimal
memory free low-watermark processor 75394
username xxxxxxxxxxxxxx
redundancy
mode none
controller Cellular 0/1/0
lte modem dm-log rotation
lte modem link-recovery monitor-timer 30
lte modem link-recovery wait-timer 30
lte modem link-recovery debounce-count 20
interface Loopback0
ip address x.x.x.x for OOB
ip nat inside
interface Loopback1
ip address X.X.X.X - Public IP assigned by telecom
--> ip nat outside
interface GigabitEthernet0/0/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/1
ip address x.x.x.x - MGMT
ip nat inside
negotiation auto
bandwidth 2000000
--> no ip address
--> ip nat outside
--> dialer in-band
--> dialer pool-member 1
--> dialer idle-timeout 0
--> dialer-group 1
--> pulse-time 1
interface Cellular0/1/1
no ip address
shutdown
interface Async0/2/0
no ip address
async mode interactive
interface Async0/2/1
no ip address
interface Async0/2/2
no ip address
interface Async0/2/3
no ip address
interface Async0/2/4
no ip address
interface Async0/2/5
no ip address
interface Async0/2/6
no ip address
interface Async0/2/7
no ip address
interface Async0/2/8
no ip address
interface Async0/2/9
no ip address
interface Async0/2/10
no ip address
interface Async0/2/11
no ip address
interface Async0/2/12
no ip address
interface Async0/2/13
no ip address
interface Async0/2/14
no ip address
interface Async0/2/15
no ip address
--> interface Dialer1
--> ip address x.x.x.x
--> ip nat outside
--> ip virtual-reassembly
--> dialer pool 1
--> dialer-group 1
no cdp enable
ip forward-protocol nd
no ip http server
ip http secure-server
--> ip nat inside source list 2 interface Dialer 1 overload
--> ip route 0.0.0.0 0.0.0.0 Dialer 1
ip route x.x.x.x 255.255.255.0 .x.x.x.x - VPN
ip route x.x.x.x 255.255.255.0 x.x.x.x - MGMT
ip route x.x.x.x 255.255.255.0 x.x.x.x - VPN2
ip access-list standard 1
permit any
ip access-list standard 2
permit any
dialer-list 1 protocol ip permit
tacacs-server host x.x.x.x
tacacs-server directed-request
tacacs-server key 7 xxxxxxxxxxxxxxxxxxxxxxxx
control-plane
line con 0
login local
transport input none
stopbits 1
line aux 0
stopbits 1
line XXX XXXX
login local
no exec
transport input all
stopbits 1
line vty 0 4
exec-timeout 30 0
login local
transport input ssh
transport output ssh
end
Hi @Georg Pauwen
I added the additional configuration and have pasted my running config below, however there we some issues which i have highlighted below
Current configuration : 8638 bytes
! Last configuration change at 19:32:36 UTC Wed May 13 2020 by net_admin
version 16.11
service call-home
boot-start-marker
boot-end-marker
no aaa new-model
call-home
active
ip domain name XXXXXXX
enrollment terminal
crypto pki certificate chain TP-self-signed-691021271
license udi pid ISR4221/K9 sn XXXXXXXX
usernameXXXXXXXXXX privilege 15 XXXXXXXXXXXXX
redundancy
mode none
interface Loopback0
ip address x.x.x.x - oob
ip nat inside
interface Loopback1
ip address Public Ip assigned by MNO /32
ip nat outside
no ip address
shutdown
negotiation auto
ip address X.X.X.X - MGMT A
ip nat inside
negotiation auto
bandwidth 2000000
no ip address
dialer in-band
dialer-group 1
pulse-time 1
***************when i try to add dialer pool-member 1 i get the below error
ub1-00-oob-wgw1(config-if)#dialer pool-member 1
%Remove Legacy DDR Configuration first
encapsualtion ppp doesn't show either
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
interface Dialer1
ip unnumbered Loopback1 -- had to use this as it would not let me directly assign a /32
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no ip http server
ip nat inside source list 2 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route X.X.X.X 255.255.255.0 XXXXX - VPN
ip route X.X.X.X 255.255.255.0 XXXXX - MGMT
ip route X.X.X.X 255.255.255.0 XXXXXXX - VON
ip route X.X.X.X 255.255.255.0 XXXXXX - VPN
permit any
permit any
tacacs-server host XXXXX
tacacs-server XXXXXX
tacacs-server XXXXXXXXXXXXXXXX
control-plane
line con 0
login local
stopbits 1
line aux 0
stopbits 1
line 0/2/0 0/2/15
login local
no exec
transport input all
stopbits 1
line vty 0 4
exec-timeout 30 0
login local
transport input ssh
end
can you try the simplified configuration below (important parts marked in bold) without the Loopback and the IP address being negotiated with SLIP ?
version 16.11
service call-home
boot-start-marker
boot-end-marker
no aaa new-model
call-home
active
enrollment terminal
redundancy
mode none
interface Loopback0
ip nat inside
interface Loopback1
ip nat outside
no ip address
shutdown
negotiation auto
ip nat inside
negotiation auto
bandwidth 2000000
ip address negotiated
encapsulation slip
load-interval 30
dialer in-band
dialer-group 1
pulse-time 1
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip http server
--> ip nat inside source list 2 interface Cellular 0/1/0 overload
--> ip route 0.0.0.0 0.0.0.0 Cellular 0/1/0
permit any
permit any
control-plane
line con 0
login local
stopbits 1
line aux 0
stopbits 1
line 0/2/0 0/2/15
login local
no exec
transport input all
stopbits 1
line vty 0 4
exec-timeout 30 0
login local
transport input ssh
end
HI @Georg Pauwen
Under the cellular 0/1/0 it does not allow me to use encapsulation slip
i get the following options
arpa Standard Ethernet version 2.0
atm-dxi ATM-DXI encapsulation
frame-relay Frame Relay networks
hdlc Serial HDLC synchronous
lapb LAPB (X.25 Level 2)
ppp Point-to-Point protocol
smds Switched Megabit Data Service (SMDS)
x25 X.25
Hi @Georg Pauwen
Adding the ip address negotiated has brought the profile up.
The original Idea was to have the interface set to a static /32 but I see now that this won't work.
I will review again with MNO.
I would just like to say thank you very much for all your help over the last 2 days
glad that you got it resolved. To be honest, up until now I had not yet seen a setup where a loopback with a fixed IP address is being used for a cellular interface. Would be interesting to know if that is indeed what the ISP wanted you to do...
HI @Georg Pauwen
The ISP got back and basically said that they hand out their Static /32 addresses via static DHCP assignment
The loopback IP was just a method I had seen on another community discussion thread, in a case where a /32 address could not be configured on a physical interface. Just a workaround
Markl
good information, thanks for the update !
