Cellular profile got inactive after reboot
John.Mayer
Hi All
I have a Cisco router with P-5GS6-GL PIM card and a LTE connection problem. it worked fine but after I rebooted the router and shut/ no shut the cellular interface, no connection came up and the profile stock was in an "INACTIVE" state
I thought that maybe the problem was because of unsync clock, so I fixed the clock by adding it manually (unfortunately I don't know why the GPS ntp reference did not work and did not show any configuration under controller cellular 0/4/0)
controller Cellular 0/4/0
controller Gps-Dr
interface Cellular0/4/0
ip address negotiated
ip nat outside
ip tcp adjust-mss 1460
ipv6 enable
rtr-01#sh cell 0/4/0 radio
Radio power mode = Online
LTE Rx Channel Number(PCC) = 3148
LTE Tx Channel Number(PCC) = 21148
LTE Band = 7
LTE Bandwidth = 20 MHz
Current RSSI = -69 dBm
Current RSRP = -101 dBm
Current RSRQ = -12 dB
Current SNR = 9.0 dB
Physical Cell Id = 129
Number of nearby cells = 4
Idx PCI (Physical Cell Id)
1 129
2 476
3 459
4 204
Radio Access Technology(RAT) Preference = AUTO
Radio Access Technology(RAT) Selected = LTE
Network Change Event = unknown
rtr-01#sh cell 0/4/0 profile
Profile password Encryption level = 7
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = tel.internet
Authentication = None
* - Default profile
** - LTE attach profile
Configured default profile for active SIM 0 is profile 1.
rtr-01#show interfaces cell 0/4/0
Cellular0/4/0 is down, line protocol is down
Hardware is 5G Advanced Pro CAT-18 pluggable-Global Multimode LTE/LTE-A/LTE-AP/DC-HSPA+/HSP
Internet address will be negotiated using IPCP
MTU 1500 bytes, BW 50000 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive not supported
Last input never, output never, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
Output 0 broadcasts (0 IP multicasts)
0 unknown protocol drops
0 carrier transitions
marce1000
 - Use latest available and or advised firmware on the Cisco router and try again ,
 M.
John.Mayer
Already checked, and there is no recommended firmware for IR1835, but I tried 17.12.1 and 17.9.4. unfortunately, both are the same
another funny thing is if I write erase the configuration and bring up the router via setup, cellular will be up and run, and if I shut/no shut the cellular interface it will down again and not come back up online again.
Hi John, did you ever get a fix or advice on this?
