01-13-2006 08:42 AM - edited 03-03-2019 11:27 AM
hi
Have tried to insert a WIC-1SHDSL-V3 into a 1841(revision 5) and i get the following error
%CFG-3-CARD_NOT_SUPPORTED: Slot 1: Unrecognized cookie format for card!
here is a show diag
WIC/HWIC Slot 1:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
Hardware Revision : 0.0
Top Assy. Part Number : 800-26571-01
Board Revision : A0
Deviation Number : 81674
Fab Version : 04
PCB Serial Number : FOC09490H0B
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Version Identifier : V02
Product (FRU) Number : WIC-1SHDSL-V3
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 04 DA 41 00 00 C0 46 03 20 00 67 CB 01
0x10: 42 41 30 88 00 01 3F 0A 02 04 C1 8B 46 4F 43 30
0x20: 39 34 39 30 48 30 42 03 00 81 00 00 00 00 04 00
0x30: 89 56 30 32 20 CB 8D 57 49 43 2D 31 53 48 44 53
0x40: 4C 2D 56 33 FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF 4A A9
Does anyone know if this version of the card is compatible with the 1841
Wai-Lun
Solved! Go to Solution.
01-15-2006 11:31 PM
hope this helps ...
Error Message
%CFG-3-CARD_NOT_SUPPORTED : Slot [dec]: [chars]
Explanation The specified line card is not recognized by the system.
Recommended Action Replace the line card with a supported line card, or upgrade the software to a Cisco IOS software image that supports this card.
regds
01-15-2006 11:31 PM
hope this helps ...
Error Message
regds
01-16-2006 03:13 AM
What Cisco model do you have ?
What Cisco IOS are you running ?
01-16-2006 03:57 AM
I was running c1841-ipbase-mz.124-1c and have now upgraded to c1841-ipbasek9-mz.124-5 which has fixed the problem.
Thanks for the help.
