E1 line with packet drops
saravanababu22
An E1 card is configured for two channels, 256kbps and 128 kbps.
both lines are generating CRC and input errors with lot of packet drops. line is checked , all loop tests are fine, modems has been checked back to back. e1 card also has been changed, still problem persists.
6 Replies 6
desai.jaideep
Level 5
Level 5
(1)You have not given model no of the E1 card and the router in which they are used?
(2)Are the E1 cards working back-to-back?
Typically they should.
(3)Also check the jumper settings for the balanced and unbalanced PRI?
Pls revert back if any probs.
JD
PS:Pls rate the helpful posts.
hi jd,
E1 is 1U-MFT, it supports only max of 2 channels.
modem used is atrie wirespan 5000.
E1 card and modem both are working fine.so where could i check this jumper settings.
its working setup, but crc should be cleared frequently, even then link goes down.
hi
will you please check is there any menu settings instead of jumper. is there a manual provoded to you.
Venugopal
in addition to the other posts, you might want to check the clock settings on your E1, make sure it is set to ´clock source line´...
GP
clock setting is set as clock source line only.
regards
Babu
Are both the cards working back-to-back without CRCs?
As you are saying its a working link, can u post the configs and the show interface output?
JD
