Changing BGP ISP Preference
Tshi M
Level 5
Level 5
I currently have BGP setup with two Internet Service Providers. Both ISP currently offers 5Mb and we are preferring ISP_1 over ISP_2. We are upgrading the bandwidth on ISP_2 from 5M to 10M and would like to use ISP_2. Would changing the local-preference of ISP_2 to a higher number do the trick.
current local-preference configuration:
route-map ISP_1-Default permit 10
set local-preference 200
route-map ISP_2-Default permit 10
set local-preference 110
Proposed change
set local-preference 300
7 Replies 7
Edison Ortiz
Increasing the local-pref on incoming routes from ISP_2 will definitely do the trick on traffic leaving your AS.
You should also work with your ISP w/ dealing on the return traffic unless you don't care how the traffic returns to you.
Edison
Thanks much Edison. I was thinking about using as-path prepend.
router bgp 65429
no synchronization
bgp log-neighbor-changes
network 208.x.x.x
timers bgp 15 30
neighbor ISP_1 peer-group
neighbor ISP_1 remote-as 1111
neighbor ISP_1 descr BACKUP ISP
neighbor ISP_1 soft-reconfiguration inbound
neighbor ISP_1 route-map ISP_1-Default in
neighbor ISP_1 route-map Route-Out-ISP_1 out
neighbor ISP_1 filter-list 50 in
neighbor ISP_2 peer-group
neighbor ISP_2 remote-as 2222
neighbor ISP_2 desc PRIMARY ISP
neighbor ISP_2 soft-reconfiguration inbound
neighbor ISP_2 route-map ISP_2-Default in
neighbor ISP_2 route-map Route-Out-ISP_2 out
neighbor ISP_2 filter-list 51 in
neighbor 206.x.x.x peer-group ISP_2
neighbor 208.x.x.81 peer-group ISP_1
neighbor 208.x.x.82 peer-group ISP_1
maximum-paths 2
no auto-summary
route-map ISP_2-out permit 10
set metric 20
route-map ISP_1-out permit 10
set metric 10
route-map Route-Out permit 10
match ip address prefix-list LIST_Out
route-map Route-Out-ISP_1 permit 10
route-map Route-Out-ISP_2 permit 10
match ip address prefix-list LIST_out
route-map Route-Out-ISP_1 permit 20
set as-path prepend 65429 65429 65429
Prepending will work as long as the ISP allows for preprending. That's the reason I suggest to work with them on the most optimal design.
Edison.
Will I have to contact both service providers or just the one that I'd like to use as a primary?
thanks again
Contact the ISP you are going to send the prepend AS to see if they allow that in their policy.
__
Edison.
I don't get it - if Etienne's preference is simply for his enterprise's network to use ISP_2 instead of ISP_1; and the route-maps are set up for this preference, what needs to be arranged on the ISP's side? I mean there isn't really a risk of ISP_2 returning traffic to Etienne via ISP_1...
...is there?
As it turned out, I made the changes last night and didn't have to call the service providers. So far so good.
