01-08-2008 11:44 AM - edited 03-03-2019 08:10 PM
1. Is it possible to channelize (more than 2 channels) all the four (4) E1 ports on a Cisco 2821 router with an NM-2CE1T1-PRI card with a VWIC2-2MFT-G703 module plugged in it.
2. Is it possible to channelize (more than 2 channels) the VWIC2-2MFT-G703 module when it is plugged directly on the router motherboard?
Thank you.
01-08-2008 02:36 PM
1. Yes. But you don't need any VWIC module plugged, NM-2CE1T1-PRI has T1/E1 ports.
2. Yes.
01-08-2008 09:10 PM
Why is it that I get the error message that "there are not enough resources" when trying to channelize the onboard VWIC2 E1 card?
01-09-2008 03:20 AM
The VWICs also support a channelized capability where the T1 or E1 service can be flexibly split into two or more fractional channel groups. Thus a single physical port can provide connection to multiple sites. (Note: when choosing this mode only a single port can be supported in each WIC slot.)
