03-17-2015 07:50 PM - edited 03-05-2019 01:02 AM
Hi all,
Like to know what is the command to check concurrent sessions that is running on my wan switch cisco4948 and wan router asr1004. TIA!
03-17-2015 11:01 PM
Hello Don,
Try Cisco IP accounting feature http://www.ciscopress.com/articles/article.asp?p=764234
Dandy
03-18-2015 04:24 AM
Hi Don,
If you have netflow enabled in the device, please make use of this command:
Router#sh ip cache flow
IP packet size distribution (49959254 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .026 .081 .064 .025 .004 .174 .008 .004 .007 .004 .003 .003 .003 .003
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
.003 .003 .003 .110 .461 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 278544 bytes
6 active, 4090 inactive, 494065 added
9661176 ager polls, 0 flow alloc failures
Active flows timeout in 1 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 34056 bytes
6 active, 1018 inactive, 494065 added, 494065 added to flow
0 alloc failures, 0 force free
1 chunk, 19 chunks added
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
TCP-Telnet 1022 0.0 23 81 0.0 2.6 9.0
TCP-FTP 96 0.0 3 46 0.0 3.4 11.9
TCP-FTPD 54 0.0 2 43 0.0 0.3 13.9
TCP-WWW 9562 0.0 5 98 0.0 0.1 2.6
TCP-SMTP 97 0.0 2 42 0.0 6.4 14.3
TCP-X 25 0.0 2 43 0.0 0.0 13.8
TCP-BGP 67924 0.0 7 49 0.1 33.4 8.0
TCP-NNTP 8 0.0 1 43 0.0 0.0 14.7
TCP-other 157116 0.0 5 250 0.2 0.2 7.0
UDP-DNS 38 0.0 2 59 0.0 0.3 15.5
UDP-NTP 42430 0.0 1 75 0.0 0.3 15.4
UDP-TFTP 19 0.0 2 56 0.0 6.2 15.5
UDP-Frag 7 0.0 2 269 0.0 0.1 15.6
UDP-other 146128 0.0 330 770 11.2 12.1 13.2
ICMP 69518 0.0 1 89 0.0 0.5 15.4
IP-other 15 0.0 1 21 0.0 0.0 15.6
Total: 494059 0.1 101 750 11.6 8.3 10.8
