Circuit Emulation over IP (NM-CEM-4TE1)
CSCO10150256
Hi All,
Hope you can offer some help...
I've configured two routers with two NM-CEM-4TE1 cards configured to allow a E1 circuit across an IP network.
Setup:
2Mbps Tester -------CEM Card ----Router A ----Fa0/0 ------ethernet switch ------Fa0/0---Router B-----CEM Card------Looped end
Router A is configured with an internal clock and Router B is configured with a Ad closed loop (Configurations enclosed).
Router A
controller E1 1/0
framing UNFRAMED
cem-group 0 unframed
clock source internal
controller E1 1/1
controller E1 1/2
controller E1 1/3
cem 1/0/0
dejitter-buffer 200
payload-compression
payload-size 256
xconnect 10.216.184.10 0 encapsulation udp
local ip addr 10.216.184.9
local udp port 15873
remote udp port 15872
interface Loopback1
ip address 10.216.184.9 255.255.255.255
Router B
ontroller E1 1/0
framing UNFRAMED
clock source adaptive 0 closed-loop
controller E1 1/1
controller E1 1/2
controller E1 1/3
cem 1/0/0
dejitter-buffer 200
payload-compression
payload-size 256
xconnect 10.216.184.9 0 encapsulation udp
local ip addr 10.216.184.10
local udp port 15872
remote udp port 15873
interface Loopback1
ip address 10.216.184.10 255.255.255.255
The configuration looks ok but I'm getting errors on the 2Mbps tester and depending on the dejitter/payload sizes error on the CEM card e.g dejitter overruns/underruns and dropped packets etc..
Do you have a configuration example that has been used in a real network? I've tried lots of changes but still can't get the 2 Mbps tester to not error...
Do you know if there is anything odd that should effect the tester? IOS Version I'm running is Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(9)T2 on both devices, I've checked didn't see anything regarding errors/bugs on this IOS.
Any help you can give would be great...
Jim.
paolo bevilacqua
Hi Jim,
I suggest you open a case with the TAC and request escalation, your application is not trivial and if the test tool is exact as I can suppose, you must get the best support to understand what is going on.
Hi Paolo,
Thanks for the advice, I have a couple of Cisco chaps working on the problem already.
I'll let you know the outcome.
Jim
