circuit taking errors
cisco steps
This is a weird connection .. at the present time the Ospf cost on  this T3  link is set to 9999 ..as there is an other route that traffic takes... once we change to cost to match the other route and traffic start flowing the links takes errors. put back to 9999 and run stress test w/ /big load there is no single error. the link can stay for days w/ ospf cost of 9999 w/ no errors. the carrier tested the ckt and all is good. any idea dear friends..
R1#sho int s1/1
Serial1/1 is up, line protocol is up
  Hardware is M2T-T3+ pa
  Internet address is 192.168.1.62/30
  MTU 4470 bytes, BW 44210 Kbit/sec, DLY 200 usec,
  Encapsulation PPP, LCP Open
  Open: IPCP, CDPCP, crc 16, loopback not set
  Keepalive set (10 sec)
  Restart-Delay is 0 secs
  Last input 00:00:02, output 00:00:00, output hang never
  Last clearing of "show interface" counters 05:03:31
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     14614 packets input, 4557522 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
              0 parity
     3 input errors, 3 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     15768 packets output, 5059370 bytes, 0 underruns
     0 output errors, 0 applique, 0 interface resets
     0 unknown protocol drops
     0 carrier transitions
   rxLOS inactive, rxLOF inactive, rxAIS inactive
   txAIS inactive, rxRAI inactive, txRAI inactive
R1 #sho run int s1/1
Building configuration...
Current configuration : 359 bytes
interface Serial1/1
ip address 192.168.1.62 255.255.255.252
ip flow ingress
encapsulation ppp
ip ospf network point-to-point
ip ospf cost 9999
ip ospf hello-interval 3
ip ospf dead-interval 9
dsu bandwidth 44210
framing c-bit
cablelength 10
serial restart-delay 0
end
R2 #sho int s2/0
Serial2/0 is up, line protocol is up
  Internet address is 192.168.1.61/30
  Last clearing of "show interface" counters 05:02:29
     15727 packets input, 5056126 bytes, 0 no buffer
              0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     14572 packets output, 4554020 bytes, 0 underruns
R2#sho run int s2/0
Current configuration : 341 bytes
interface Serial2/0
ip address 192.168.1.61 255.255.255.252
encapsulation ppp
ip ospf cost 9999
dsu bandwidth 44210
framing c-bit
cablelength 10
end
11 Replies 11
vmiller
Level 7
Level 7
what kind of errors? input & CRC speak to a physical layer problem (cable/ port)
  4649 input errors, 4530 CRC, 0 frame, 117 overrun, 0 ignored, 2 abort
You have a faulty circuit, complain to telco.
Thanks Paolo , there is no way to prove that .. the telco provies a loopback facing both side of the ckt and it comes clean many times. so how I can prove that this is a telco issue/
Thanks all
Yes there is.  It's called a disruptive end-to-end Bit Error Rate (BER) test.  The mere suggestion to the telco by the customer alone can cause shivers in the back of the spine of the telco.  Sometimes the request to conduct this test can "uncover" line errors that was once deemed as "clean" by the telco.
Trust Paolo.
leolaohoo
Thanks , the carrier did the bert test and concluded no errors. and they pointed the finger to the protocol . I do not know what protocol they were talking about. But I agree w/ Paolo and the rest . I just need to find a way to convince them that this is their issue .
Have the BER test done in front of you.
Loopbak one end, BER tester the other.
Again: make sure you personally observe it .
Per cisco website BERT test are not supported on T3 link...
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/bert.html
Is that true ?
What we are telling you, use an EXTERNAL T3 tester.
Not the router.
I've worked with serials for four years.  9 out of 10 complaints about "dirty" line and the telco will always say it's "our" equipment fault.  Now before I will continue, during that time (2001 to 2005), the telco I would deal with use software-driven to conduct a quick test.  Accuracy of the test is akin to sinking a hole-in-one at St.  Andrew's 1st hole on a windy day.
Back to the story:  Anyway, I would verify their "findings" by putting our Nortel WAN link into a loop condition and tell the telco to "fire" their test.  Guess what their NEXT response is?
My point is:  Unless you have something to verify the telco's findings, don't trust their word.  The less work for them the more money they make from you.  What Paolo has recommended will most-definitely bring accurate results.  Loopback at the telco's exchange (the-nearest-exchange-from-your-site and move further away) and a BER hardware at your site.
BER tests, because of the amount of money you throw at the telco, is mostly free.  The telco has the obligation to ensure the services they provide to you are within standards.  Dirty lines, unfortunately, isn't part of that standard.  Whenever you deal with the telco, take down the exact time, date, person you dealt with and the synopsis of the conversation.  You will need these information when you escalate or take "action".
Two famous telco quotes."The trouble is leaving here just fine"   and "Cleared on Testing"
