Cisco 1130ag Access Point Image Upgrade
humair.amil
Hi all,
I was just trying to upgrade my first cisco access point at home. I am a bit lost...
a) I can't run "conf t" command.
b) It seems to have ver 3 or ver 4 lwapp image running on it.
c) keeps rebooting itself when it starts up and says "certificate is invalid"
I am attaching some screenshots, if you could have a look when you have a minute and guide me in the right direction then I will be highly grateful to you.
Thanks.
27 Replies 27
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.100.60
RTOS Version..................................... 7.4.100.60
Bootloader Version............................... 7.4.100.60
Emergency Image Version.......................... 7.4.100.60
Build Type....................................... DATA + WPS
System Name...................................... Cisco_b9:b6:23
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 192.168.1.240
System Up Time................................... 0 days 0 hrs 4 mins 32 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... GB  - United Kingdom
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 00:0C:29:B9:B6:23
Maximum number of APs supported.................. 200
I have made changes
No you haven't.
Configured Country............................... US  - United States
If you did, this output would be different.
Sorry, That was the old config that I pasted, please check the new one that I just updated.
Very funny.    Ha ha ha ...
Same song-and-dance.  If you've just configured the WLC for GB and you've rebooted the WLC, console into the AP and post the entire bootup process.
PS:  Your last console, did NOT have enough information.  Leave the console running for another 5 minutes after power up,.
here u go...
File "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1130 Software (C1130-RCVK9W8-M), Version 12.3(11)JX1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:38 by alnguyen
Image text-base: 0x00003000, data-base: 0x0035E440
Initializing flashfs...
flashfs[1]: 8 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 5496832
flashfs[1]: Bytes available: 10502144
flashfs[1]: flashfs fsck took 3 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
cisco AIR-LAP1131AG-E-K9   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FCZ1225Q1JN
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from reload
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1E:F7:EE:58:76
Part Number                          : 73-8962-12
PCA Assembly Number                  : 800-24818-11
PCA Revision Number                  : B0
PCB Serial Number                    : FOC12230B10
Top Assembly Part Number             : 800-29144-02
Top Assembly Serial Number           : FCZ1225Q1JN
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1131AG-E-K9
Press RETURN to get started!
*Mar  1 00:00:06.074: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar  1 00:00:06.080: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:07.036: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:08.036: %LINEPROTO-5-UP
ap>DOWN: Line protocol on Interface FastEthernet0, changed state to up
ap>en
Password:
ap#
*Mar  1 00:00:25.099: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar  1 00:00:36.502: LWAPP_CLIENT_ERROR_DEBUG: spamHandleDiscoveryTimer : Found the discovery response from MASTER Mwar
*Mar  1 00:00:36.511: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Jun 22 01:08:16.002: LWAPP_CLIENT_ERROR_DEBUG:
*Jun 22 01:08:16.002: peer certificate verification failed
*Jun 22 01:08:16.002: LWAPP_CLIENT_ERROR_DEBUG: spamDecodeJoinReply : Certificate is not valid
*Jun 22 01:08:16.003: LWAPP_CLIENT_ERROR_DEBUG: Unable to decode join reply
*Jun 22 01:08:20.977: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not recieve the Join response
*Jun 22 01:08:20.977: LWAPP_CLIENT_ERROR_DEBUG: No more AP manager IP addresses remain.
*Jun 22 01:08:21.014: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET JOIN RESPONSE.
*Jun 22 01:08:21.014: %LWAPP-5-CHANGED: LWAPP changed state to DOWN
Errrr ... something is very missing from your output.
Your AP is NOT getting an IP Address.  And you've possibly got an MSC problem.
I assigned a static IP Address to Fa0/0 and still it does that.
Shall I take it off and get the WLC to assign IP Address to AP via dhcp?
Also, sorry, what is MSC?
Post the output to the command "sh ip int brie" from the AP.
Next, from the AP, ping the Management IP Address of the WLC.
144AP1#show ip int br
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              192.168.1.127   YES other  up                    up
144AP1#ping 192.168.1.240
Sending 5, 100-byte ICMP Echos to 192.168.1.240, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
I am just wondering, I did check earlier but just want to make sure, are Cisco 1130ag APs compatible with Cisco Virtual Wireless LAN Controller?
Post the output when you enter the following command (enable mode and NOT configuration mode): capwap ap controller ip address 10.168.1.240
What is the network topology like?  Is there a Firewall sitting between the WLC and the AP?
The Cisco 1130ag access points do not support capwap I guess. I have used the command lwapp ap controller ip address 192.168.1.240 but it makes no difference.
There is no firewall between the AP and the WLC. I had a switch connecting the two but now I have connected the AP directly to the WLC and they can ping each other.
I cannot enter configuration mode. It does not recognize the "conf t" command either.
Any ideas ??
This doesn't add up.
HOW did you manage to assign an IP address when an AP boots up?
You cannot save the config when you boot up.
