Cisco 1760 with SHDSL
kolawole1
I have a cisco 1760 router with one adsl wic and one shdsl wic (wic 1 shdsl v3).The router has detected the adsl wic but not the shdsl.I am using the following software:c1700-y7-mz.123-4.XG5.bin.I have tried several ios and used feature navigator to find ios but neither works.Here is output of sh version
Can somedy help ?
paolo bevilacqua
According to documentation:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gt4wire.html
You need a minimum of 12.4(2)Xa or 12.4(5) to support that hardware.
Note you also will probably need a RAM and flash upgrade to host that newer IOS.
Thanks Using feature navigator it realised that i only need 48 MB DRAM and 16 MB FLASH to run 12.4(5) ios.
In my case do i still need an upgrade based on my sh ver ?
Check with the actual image.
