Cisco 1801 ATM -> Ethernet bridge issue
azaghul33
I recently purchased a UC520W for use at home to replace an 877W, would  like it to do all the front-end stuff, NAT, firewall, PPPoE, voice. Have  installed a 1801 in front of it to bridge ADSL to Ethernet (almost),  but having some issues.
1801 config:
no ip routing
interface ATM0
description OUTSIDE
no ip address
no ip route-cache
no atm ilmi-keepalive
pvc 8/3
  vc-hold-queue 1024
  encapsulation aal5snap
  exit
bridge-group 1
no shut
exit
interface FastEthernet0
description INSIDE
no ip address
no ip route-cache
speed 100
full-duplex
bridge-group 1
no shut
exit
bridge 1 protocol ieee
The UC520W is doing the PPPoE negotiation fine, so the 1801 is bridging  (I've tried an 877W as well), I can ping out from the UC520 and attached  PCs OK as well. But when it comes to email and web surfing....no joy.  Replacing the 1801 with a dumb domestic modem/router in bridge mode works without  issue.
Have tried bridge irb (both enabled/disabled) and also ip routing (both enabled/disabled), no change.
Why am I getting only a partial connection? Any thoughts welcome....and  just using the domestic modem/router is the ultimate fall back solution, but I'd like  to work out where its failing if I can.
antonio.guirado
Level 3
Level 3
Please, check you MTU in all the links. I think the problem could be the MTU in some interface.
Regards.
antonio.guirado
Level 3
Level 3
Regards.
Looks to have been an MTU problem (which was on my to-do list [but forgotten]), configured for 1452 on both the ATM and FastEthernet interfaces on the 1801 and FastEthernet on the UC520, all OK for the past 24 hours.
Thanks for the assist!
paolo bevilacqua
You will have better results by using a cheap modem like the default ISP one, as bridge.
