Cisco 1841
tahseen12
Router 1841 doesn;t show temperature status when I run command sh env whereas 2800 is showing.The IOS is 12.4 on both
Kindly suggest??
Output:
sh env
FAN 1 Running sucessfully
ILP Power Supply - Absent
5 Replies 5
paolo bevilacqua
the 18xx does not support temperature monitor, where did you saw differently ?
hope this helps, please rate post if it does!
Do you have any link saying this
It works on 2800 but not in 1800
1800 and 2801 does not have a temperature sensor.
2811 and bigger models do have.
This is the way it is.
No dear its not correct it does have onboard temp sensor
Please check this link
http://www.cisco.com/en/US/products/ps5853/products_installation_guide_chapter09186a0080458a31.html
Still not able to figure out why its not showing temp with sh env command
I think you have misread the document. It does not says that the 1800 has a temperature meter, it simply says that the FAN is temperature-controlled:
Cisco 1800 series fixed-configuration routers have an internal multispeed fan that provides chassis cooling, controlled by an onboard temperature sensor. The internal fan operates at a continuously variable speed to minimize fan noise while providing sufficient chassis cooling.
So you can go around as much as you want, no thermometer, sorry.
