Cisco 1921/K9 Router DHCP Problem
Samuel Berhanu
I configured the Cisco 1921 DHCP server but does not lease an IP address to the host....
SN: FCZ2138B0MJ
5 Replies 5
Samuel Berhanu
ip dhcp excluded-address 10.1.10.1 10.1.10.10
ip dhcp pool Addis-Villa-Sample
network 10.1.10.0 255.255.255.0
default-router 10.1.10.1
dns-server 213.55.96.148 213.55.96.166
domain-name addis-villa.com
lease 7
no ip domain lookup
ip name-server 213.55.96.148
ip name-server 213.55.96.166
ip dhcp-server 10.1.10.1
license udi pid CISCO1921/K9 sn FCZ2138B0MJ
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Connect-to-ISP
ip address 196.188.1.104 255.255.224.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description Connect-to-ZYXEL-AGG
ip address 10.1.10.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 196.188.0.1
access-list 1 permit 10.1.10.0 0.0.0.255
Share
Show ip dhcp statistics
Here let me check
MHM
Hello @Samuel Berhanu
Try to re enable dhcp service on your router
#service dhcp command under configuration-terminal.
Best regards
Samuel Berhanu
Info:- Cisco Packet Tracert worked for me but on the physical router it didn't work, what is the issue....
Hello
Is it possible you can post the run cfg of the real router, Also a simple topology diagram showing the rtr to client physical connection?
Kind Regards
Paul
