Static to BGP redistribition
Russel
how to redistribute static routes in bgp? What is the configuration to be able to do this in packet tracer? Can you give an example in another way. Thank you.
Can you help me ??
MyAARPMedicare
Seb Rupik
Hi there,
The configuration will look like:
router bgp xxxx
   redistribute static
This will redistribute all static routes into the BGP process. You may want to add a route-map to filter out some of these routes.
As for 'another way' can you elaborate?
cheers,
Seb.
Make new post and mention the software you use for lab
MHM
Hello @shopia452 ,
if all you need is to advertise some static routes you can use the network command under router bgp .
BGP just checks that the prefix is in the IP routing table it is not limited to connected routes like the network command in IGPs
note: you need to use the network command with the exact mask as you see in the routing table
Hope to help
Giuseppe
Hello
I would suggest be as specific as possible when you want to redistribute prefixes, static routes is no exception, In this caser I would utilise a route-map and tag the static routes so no future static(s) is advertised by default
ip route x.x.x.x y.y.y.y <interface> <next-hop ip>  tag 100
route-map Static_Routes_RM
match tag 100
router bgp xx
address-family ipv4
redistribute static route-map Static_Routes_RM
Kind Regards
Paul
