cisco 1921 NAT RDP Problem
stan.kravets
Hello, I am fairly new here, this is my first post. I have been trying to tackle this issue on my own to no avail. I have a Cisco 1921 to replace our current router which is constantly freezing. We have a couple inside servers, one is a web server and application server which needs to be RDP'd to by a couple of clients outside of our network. I cannot get this to work no matter what. I know it's not the server's setup as when I plug the network back into the old router, it works just fine.
All clients have access to the internet, and I can successfully ping/resolve hosts from both the router and a client computer connected. I cannot, however, rdp using neither our public IP, nor our hostname. The hostname does resolve to our ISP assigned IP, but the server cannot be contacted, leading me to belive this is a NAT issue. My config file is below. Any help would be greatly appreciated. THANKS!
Current configuration : 4643 bytes
! Last configuration change at 00:18:20 UTC Sun Jan 20 2013 by ***Admin
version 15.1
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service compress-config
hostname ***Office_Local
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 /x.XXZBXS7rpLl3dj39.iDAFlt5lGcjTiUlUCQucW3U
no aaa new-model
no ipv6 cef
no ip source-route
ip cef
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp pool LAN
network 10.1.1.0 255.255.255.0
domain-name *****************.com
dns-server ***.***.***.2 ***.***.***.250
default-router 10.1.1.1
no ip bootp server
ip name-server ***.***.***.2
ip name-server ***.***.***.250
ip name-server 8.8.8.8
crypto pki trustpoint TP-self-signed-810841858
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-810841858
revocation-check none
rsakeypair TP-self-signed-810841858
crypto pki certificate chain TP-self-signed-810841858
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 38313038 34313835 38301E17 0D313231 30323932 31303732
  345A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3831 30383431
  38353830 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  C925E5CB 784751A9 A03B0B5E 42B3AECA 7C04F3B3 29C06A3C 6CD3DC9C D842304F
  A99358BF 461F2019 4CF44369 1F463CAB 35FCFCCE 9FC3A5CC AD42EE14 83069FB2
  2AC82A69 146C265F 1595C4EA DF81AD83 4751A2DA A164ACFC 0FE36ED3 44544D66
  22E425A2 AC80DCC5 10ADC41A E2C4F4EE B98651C4 FB44FB1F 565B31C0 ACD82315
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 168014D1 367C56F0 E54B0E34 3CEDE18B DB7D5262 8D57ED30 1D060355
  1D0E0416 0414D136 7C56F0E5 4B0E343C EDE18BDB 7D52628D 57ED300D 06092A86
  4886F70D 01010505 00038181 006783F1 F2A10C59 F13EBE29 9BD17BB3 0D3138C5
  7664CD13 73E655BC DBC9C90E 8426D481 44E9D3E7 770EED7A 2AC09C70 467B06BD
  01F00AF9 4C94BA64 57DB99CC BCA9B746 6F49631C 3978EFF8 1ECE898C 3DAC8445
  068F3674 68C10BDC 830729AA 995C493C FA52EC6E 1EBE7F27 D04BD8B8 80F8DB1B
  E7C1D8E9 5C897E14 F40ABDE1 B9
        quit
license udi pid CISCO1921/K9 sn FGL16442155
username ***Admin privilege 15 secret 4 /x.XXZBXS7rpLl3dj39.iDAFlt5lGcjTiUlUCQucW3U
username admin privilege 15 secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
redundancy
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-WAN$
ip address ***.***.***.210 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
interface GigabitEthernet0/1
description Internal LAN$ETH-LAN$
ip address 10.1.1.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool NAT_LAN ***.***.***.210 ***.***.***.210 prefix-length 30
ip nat pool RTP_FWD 10.1.1.5 10.1.1.5 netmask 255.255.255.0 type rotary
ip nat inside source list 10 pool NAT_LAN overload
ip nat inside source static tcp 10.1.1.181 3389 interface GigabitEthernet0/0 3395
ip nat inside destination list 100 pool RTP_FWD
ip route 0.0.0.0 0.0.0.0 ***.***.***.209
access-list 10 remark CCP_ACL Category=18
access-list 10 permit 10.1.1.0 0.0.0.255
access-list 23 permit 10.1.1.0 0.0.0.255
access-list 100 remark CCP_ACL Category=18
access-list 100 permit udp any any range 10000 20000
access-list 100 permit tcp any any eq 3395
access-list 100 permit tcp any any eq 3389
control-plane
line con 0
exec-timeout 5 30
password 7 107C4D0E091815020F55786A
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
XIE YAO
What's the ip address of the RDP server?
It appears to be that 10.1.1.181 with RDP port 3389 is mapped to ip of G0/0 with port 3395, while somehow you also configured a destination nat (normally used for load share, but not in this case) to nat tcp 3389, 3395, and udp 10000-20000 to destination 10.1.1.5
Yaoxie
cadet alain
Can you do this:
no ip nat inside source static tcp 10.1.1.181 3389 interface GigabitEthernet0/0 3395
no ip nat inside destination list 100 pool RTP_FWD
ip nat inside source static tcp 10.1.1.181 3389 interface GigabitEthernet0/0 3389
Also why did you use a rotary pool ?
Regards.
Alain
