Cisco 1941 mini USB console port access
charles cht
Hi everyone,
At present, our company is using a router cisco1941, the original RJ45 console port has been damaged, recently I need to connect it to modify the Settings, I can not access the device using the USB mini port. My laptop is running the version of Win 10 22H2 and has installed Cisco USB driver. Do you have any solutions?
M02@rt37
Hello @charles cht,
Please read this:
https://community.cisco.com/t5/routing/usb-console-driver-install-failing/td-p/1943982#comment-9697916
Best regards
pieterh
For some routers Cisco moved to another driver
maybe this also helps for the 1941
Cisco Catalyst IR1101 Rugged Series Router Software Configuration Guide - Introduction [Cisco Catalyst IR1100 Rugged Series Routers] - Cisco
If your laptop or PC warns you that you do not have the proper drivers to communicate with the router, you can obtain them from your computers manufacturer, or go here:  https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
