Cisco 2500 Series - Serial Number Command
gwhansen59
All,
Is there a command for Cisco 2500s running 12.x to obtain the chassis serial number? I've been looking everywhere and can't seem to find one. I don't think the 'show version' command is a command to use for obtaining the serial number either. Will a 'show inventory' or 'show idprom' command work?
GH
paolo bevilacqua
There is no command available on the 2500 to see the serial number, independently from the software version or model used.
Thank you much!
singhrandheer71
Retrieving the Unique Device Identifier on Controllers with CLI
Procedure
• show inventory—Shows the UDI string of the controller.
• show license udi—Shows UDI values for licenses.
Those are appropriate commands for more modern devices and OS. But the original question was about 2500 series routers running 12.x code. Those commands are not available for that hardware and that version of code.
Rick
