RV160 HTTPS port forwarding error
DorsetDavey
I have a quite basic set up on my rv160, I don't use VPN so the error I am getting seems a little odd. I am trying to set up HTTPS port forwarding to an internal host. However, when I select HTTPS traffic for both external to internal service I get this error under HTPPS for external interface:
The port of External Service is duplicate with RESTCONF / NETCONF / Remote management / SNMP / OpenVPN!
I am completely snookered now, I have no idea what this means or how to fix it. Anyone can help?
The answer to this issue was to go to (using web management UI) Firewall > Basic Settings ...and then disable RESTCONF & NETCONF (since I didn't them, if you do change the RESTCONF from port 443 to another port number).
Hello
I believe you only need to select an external service so port forwarding is allowing ingress from a external host internally into your lan
Kind Regards
Paul
You have to add an internal service to map to, I have attached a screen shot, I wish Cisco would stay out of the small business market if they are going to make it so you need a Cisco engineer to perform such basic operations.
Hello
Ive never used these boxes however PF principle is relatively the same
If you haven’t already please review RV160 PF
Kind Regards
Paul
