Cisco 2505 Ruter, very old
mariano.deheza
Hello All,
I'm looking for documentation, firmware, etc for an old Cisco 2505 router. It has 8 ethernet ports, behind. I've searched on cisco.com but there is no much data. Is there some FTP site from Cisco, as happens with some other big companys?
Kind regards, and thank you for any response or hint or data.
Mariano
2 Accepted Solutions
as Philip said, that product went EoL in 2005 (I think). Below is a link to IOS versions, not sure if they are working...
https://sobek.su/Cisco/IOS/25xx/
Dan Lukes
Some documentation covering 2505 can be found here.
6 Replies 6
Philip D'Ath
This product went "end of support" a very long time ago, and at the same time all the software for it was removed.
Hello Philip! Thank you for your quick response. Yes, I know that is too old :-) Kind regards!
Thank you a lot, Georg. It seems that the firm is there. Kind regards,
Mariano
Dan Lukes
Thank you a lot, Dan. It seems that the solution is here too.
Thank all of you for your support.
Kind regards,
Mariano
