Policing Traffic
jasongr33nway
I am trying to find a way to manage the traffic from a CDN. NBAR is not supported on our L3 Switch so I decided to try and police the traffic at our branch locations. I have the policy map configured but it doesn't appear to be working since I have seen this traffic inbound since I applied the policy.
Class-map: WSUS (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: protocol http host "*.akamaitechnologies.com"
      Match: protocol http url "*.deploy.static.akamaitechnologies.com"
      police:
          cir 800000 bps, bc 25000 bytes
        conformed 0 packets, 0 bytes; actions:
          transmit
        exceeded 0 packets, 0 bytes; actions:
          drop
        conformed 0 bps, exceed 0 bps
The site I am trying to limit is coming from "a104-94-197-105.deploy.static.akamaitechnologies.com"
7 Replies 7
Hi jasongr33nway,
Can you post all the configuration related to this policy.
And try this
Match: protocol http host "*.akamaitechnologies.com$"
Match: protocol http url "*.deploy.static.akamaitechnologies.com$"
This class map is configured as match all so both conditions must be matched. Is this what you want to achieve?
Spooster IT Services Team
So I am opening this back up because I don't understand why I can't police via http host or url. I have applied this policy to an ingress interface and I am not getting any hits on it.
Here is the policy I have set as an input policy.
GigabitEthernet0/2
Service-policy input: HTTP-POLICE
    Class-map: Test (match-any)
      0 packets, 0 bytes
      Match: protocol http host "*.deploy.static.akamaitechnologies.com"
        0 packets, 0 bytes
        5 minute rate 0 bps
        0 packets, 0 bytes
        5 minute rate 0 bps
        0 packets, 0 bytes
        5 minute rate 0 bps
        0 packets, 0 bytes
        5 minute rate 0 bps
      police:
          cir 500000 bps, bc 15625 bytes
          transmit
          drop
        conformed 0000 bps, exceeded 0000 bps
    Class-map: class-default (match-any)
      50442397 packets, 44101904476 bytes
      5 minute offered rate 8876000 bps, drop rate 0 bps
      Match: any
Here is the class-map
Class Map match-any Test (id 5)
   Match protocol http host "*.deploy.static.akamaitechnologies.com"
   Match protocol http url "*.deploy.static.akamaitechnologies.com"
   Match protocol http host "*.akamaitechnologies.com$"
   Match protocol http url "*.deploy.static.akamaitechnologies.com$"
Some of the traffic this morning that should have been hit
a184-24-98-239.deploy.static.akamaitechnologies.com (184.24.98.239)
what platform is this one ? QoS is different for every switch model.
Can you post the full configuration ? Everything goes to the default class, you might want to try and match an access list specifying your source IP addresses...
This is off our 2921. All the others are 2911s. I thought about doing an acl the issue is the traffic is coming from a CDN and the IP is always different.
Here is the Policy Maps on that interface.
      0 packets, 0 bytes
        0 packets, 0 bytes
        5 minute rate 0 bps
        0 packets, 0 bytes
        5 minute rate 0 bps
        0 packets, 0 bytes
        5 minute rate 0 bps
        0 packets, 0 bytes
        5 minute rate 0 bps
      police:
          transmit
          drop
      60165644 packets, 52913747462 bytes
      5 minute offered rate 2553000 bps, drop rate 0 bps
      Match: any
  Service-policy output: QOS-OUTBOUND
    queue stats for all priority classes:
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 107421541/31905624158
    Class-map: ATT-QUEUE-1 (match-any)
      107421541 packets, 31897869410 bytes
      5 minute offered rate 209000 bps, drop rate 0 bps
      Match: access-group 2001
        107421539 packets, 31897869410 bytes
        5 minute rate 209000 bps
      Priority: 20% (2000 kbps), burst bytes 50000, b/w exceed drops: 0
    Class-map: ATT-QUEUE-2 (match-any)
      42787172 packets, 30776798033 bytes
      Match: access-group 2002
        5 minute rate 0 bps
      Queueing
      (pkts output/bytes output) 42787172/30776798033
      bandwidth remaining 30%
    Class-map: ATT-QUEUE-3 (match-any)
      284990352 packets, 114698453022 bytes
      5 minute offered rate 3973000 bps, drop rate 0 bps
      Match: access-group 2003
        284990313 packets, 114698455657 bytes
        5 minute rate 3973000 bps
      Queueing
      queue limit 512 packets
      (queue depth/total drops/no-buffer drops/flowdrops) 0/22/0/22
      (pkts output/bytes output) 284990331/114723062095
      bandwidth remaining 60%
      Fair-queue: per-flow queue limit 128 packets
      397214 packets, 23943408 bytes
      Match: any
      (pkts output/bytes output) 2473946/2202532994
try and simplify your class map like this:
class-map match-any Test
 match protocol http host *akamaitechnologies*
match-all...try match-any.
What switch/platform (e.g. 3750) do you have ?
jasongr33nway
Hey guys, thanks for all your input. I ended up policing all https traffic. I found updates coming from many different sites.
