Cisco 2509RJ as Access Router in CCIE LAB
atuldalvi
Dear Sir,
I have Cisco 2509RJ Router with me. Can I use this router as a access server in my CCIE lab..
Please reply!!!
Thanks/Regards
Atul
Prashanth Krishnappa
Did you mean to say as a terminal server to reverse telnet into other devices? Is so, yes you can. I believe 2509 has 8 Async lines. You will need an octal cable as well.
Create a loopback interface that will be used for the reverse telnet sessions from the other devices.
Router(config)#interface loopback0
Router(config-if)#ip address 172.16.1.1 255.255.255.255
Now add the devices that are connected to this router [octal cable to each console port]
Router(config)#ip host hostname 2001 172.16.1.1
Router(config)#ip host hostname2 2002 172.16.1.1
With this you should be able to telnet using "telnet 172.16.1.1 2001" and so on.
thisisshanky
Level 11
Level 11
Atul,
Since you have a 2509RJ, you dont need the octal cable.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
