Cisco 2511 Terminal Server
GREGORY JACKSON
I am having some dificulties with my terminal server:
1#sho ver
IOS (tm) 2500 Software (C2500-I-L), Version 12.1(27b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 16-Aug-05 22:38 by pwade
Image text-base: 0x03041FDC, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTLDR: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFTWARE (fc1)
T1 uptime is 43 minutes
System image file is "flash:c2500-i-l.121-27b.bin"
cisco 2511 (68030) processor (revision M) with 14336K/2048K bytes of memory.
Processor board ID 12023738, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
16 terminal line(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
I know it's old code and I will upgrade it soon but right now I just want to get my reverse telnet working.
Here what I have so far:
Building configuration...
Current configuration : 664 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname T1
ip subnet-zero
ip host r1 2001 1.1.1.1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
no fair-queue
interface Serial1
no ip address
shutdown
ip classless
ip http server
line con 0
exec-timeout 0 0
line 1 16
no exec
transport input all
stopbits 1
line aux 0
line vty 0 4
login
end
I'm using Sevure CRT 6.7.
Wehn I type in "r1" I get the following message "Trying r1 (1.1.1.1, 2001)... Open" and that it I get no further.  I use the break squence to get back to the terminal server prompt and I run "sho session" and get the following output:
T1#sho session
Conn Host                Address             Byte  Idle Conn Name
*  1 r1                  1.1.1.1                0     0 r1
T1#r1
It appears that my session is connected i just get no response my screen just stay locked on the "T1#r1
Any suggestions...
g
11 Replies 11
mbilgrav
Level 3
Level 3
it doesnt make sense to me why you want to connect to the router that you allready are connected to ...
anyway - : Did you try and hit "enter" ?
also I think you need to provide a password.
what does your SecureCRT say when you telnet ?
are you connecting and line combo-cables ?
I am not sure that the router will start a listner on port 2001 just because you give it an "ip host" command.
Martin
Thanks for the response -- I am using a asynchronous 8 octal cable connect to the router. The router is connected to the octal cable 1 which translates to 2001 when I configure the reverse telnet. I'm consoled into my terminal server and from my # prompt I type "r1" or telnet 1.1.1.1 2001.
Hi Gregory,
what does 'sh line' tells you?
also, make sure you have the octal cable inserted into the right slot, I think 2001 will respond on slot 0's first cable etc.
Did you try to telnet 1.1.1.1 2001 from a remote pc?
Martin,
have a look - http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
Ivan.
Thanks for your response. I cannot telnet to the device from a pc I have not configured the LAN yet. I have tried to telnet from the terminal server directly and got same results. Just seem to hang at the ".... Open" state. I would like to know of a good cable matrix showing what cable is 1 to 8 on the octal cable. They are labeled but I'd like to validate. Also are there any good debug commands that can help other than the debug asynchronous packet.
Gregory,
normally if the cable is labeled it should correspond to the right pins on the connector, a big doubt if there's a way to check this. Is that box, r1, powered up? Have you tried to console to it directly? any non-default settings on its console? Did you check as per my previous suggestion if the module is in the appropriate slot?
Cheers,
Ivan.
R1 is powered and I can console to it directly using secureCRT and the cisco provided cables, nothing on the device preventing connectivity. Can't do a show line as I'm away from the equipment. I can do that later this evening. I have looked at the supporting documentation and that along with a few others I referenced when I did the original configuration.
I have access to my terminal server I have connected to it via console cable. I ran the "show line" command after trying to attach to the router and I also added a sw1 on 2009. See output below:
T1#sho line
   Tty Typ     Tx/Rx    A Modem  Roty AccO AccI   Uses   Noise  Overruns   Int
*    0 CTY              -    -      -    -    -      0       0     0/0       -
     1 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
     2 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
     3 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
     4 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
     5 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
     6 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
     7 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
     8 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
     9 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
    10 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
    11 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
    12 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
    13 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
    14 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
    15 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
    16 TTY   9600/9600  -    -      -    -    -      0       0     0/0       -
    17 AUX   9600/9600  -    -      -    -    -      0       0     0/0       -
    18 VTY              -    -      -    -    -      0       0     0/0       -
    19 VTY              -    -      -    -    -      0       0     0/0       -
    20 VTY              -    -      -    -    -      0       0     0/0       -
    21 VTY              -    -      -    -    -      0       0     0/0       -
    22 VTY              -    -      -    -    -      0       0     0/0       -
T1#sho run
version 12.1
hostname T1
ip subnet-zero
interface Loopback0
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
no fair-queue
interface Serial1
no ip address
shutdown
ip classless
ip http server
line con 0
exec-timeout 0 0
line 1 16
no exec
transport input all
stopbits 1
line aux 0
line vty 0 4
login
end
T1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
T1(config)#ip host sw1 2009 1.1.1.1
T1(config)#^Z
T1#
00:02:45: %SYS-5-CONFIG_I: Configured from console by consolesw1
Trying sw1 (1.1.1.1, 2009)... Open
T1#r1
T1#sho line
*    0 CTY              -    -      -    -    -      2       0     0/0       -
*    1 TTY   9600/9600  -    -      -    -    -      1       0     0/0       -
*    9 TTY   9600/9600  -    -      -    -    -      1       0     0/0       -
T1#
Still no sucess to eitehr sw1 or r1?
Found the problem needed to have flow control dtr/dsr selected in the session options in secureCRT
Gregory
Thanks for posting back to the forum indicating that you have solved the problem and what the solution is. I have seen quite a few questions about problems with terminal servers but very few bring up the issue of flow control in the emulator. So this is very helpful.
Rick
Rick
I have a problem with my terminal server . line 1-8 connects sucessfully, but 9-16 does not connect, but stays open. Can someone help please
2500series#R9
Trying R9 (192.168.30.1, 2009)... Open
 NOTHING HAPPENS AFTER THIS
2500series#show lin
7 TTY 9600/9600 - - - - - 0 1 0/0 -
8 TTY 9600/9600 - - - - - 7 0 0/0 -
* 9 TTY 9600/9600 - - - - - 3 0 0/0 -
* 10 TTY 9600/9600 - - - - - 1 0 0/0 -
14 TTY 9600/9600 - - - - - 0 2 0/0 -
15 TTY 9600/9600 - - - - - 0 1 1/0 -
17 AUX 38400/38400 - - - - - 0 0 0/0 -
* 18 VTY - - - - - 13 0 0/0 -
--More--
