Vlan mismatch effects?
louis0001
Level 3
Level 3
Our MPLS provider asked us to peer on vlan 4094 using a /30. Now, silly me put in vlan 4096 by mistake.
Traffic still flows though. Is there likely to be any side effects of this eg latency, packet loss etc?
Joseph W. Doherty
If it's an untagged (non-trunk) port, only CDP, if active on both sides of the link, would complain about a VLAN mismatch. No impact to untagged traffic.
Please could you clarify that. This is a CE router with an interface configured as g0/0/1.4096 so I would assume all packets are tagged? This peers with their PE router.
Yes, with a subinterface on the router, frames should be tagged.
If other side of link router (the PE) is expecting differently tagged frames I would expect other side to either ignore them or direct them into the wrong VLAN or subinterface. However, you note traffic is flowing, correct? If so, I'm surprised it works.
Doh, my mistake. I didn't notice that interface was g1/0/0.4096 and encapsulation was 4094 which explains why data was flowing. Thanks for the help.
