Cisco 2600 802.1q sub interface and IPSEC
subra4u
We are trying to set up a tunnel with a sub interface (but with no luck)and would like to know if some one has tried creating an ipsec tunnel using a sub interface in a cisco 2600.
Thx in advance,
subra
Dennis Mink
what is the issue and can you include the config?
Please remember to rate useful posts, by clicking on the stars below.
Below is the requested config.......
sh run
Building configuration...
Current configuration : 2729 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
boot-start-marker
boot-end-marker
no ip subnet-zero
ip cef
no ip domain-lookup
crypto isakmp policy 1
encr 3des
authentication pre-share
crypto isakmp policy 20
encr 3des
group 2
crypto isakmp key dsfgf address 8.2.8.6
crypto ipsec transform-set TS1 esp-3des esp-sha-hmac
mode transport
crypto map cm1 20 ipsec-isakmp
set peer 8.2.8.68
set transform-set TS1
set pfs group2
match address 102
call rsvp-sync
interface Tunnel1
description **** RX ****
bandwidth 256
ip address 13.30.63.10 255.255.255.252
tunnel source FastEthernet0/0.756
tunnel destination 8.52.8.68
no clns route-cache
crypto map cm1
interface FastEthernet0/0
no ip address
no ip mroute-cache
duplex auto
speed auto
no cdp enable
no clns route-cache
interface FastEthernet0/0.50
encapsulation dot1Q 50
ip address 8.11.6.1 255.255.255.0
no cdp enable
interface FastEthernet0/0.756
encapsulation dot1Q 756
ip address 8.11.6.5 255.255.255.240
no cdp enable
crypto map cm1
Leo Laohoo
Where's the config of the remote router?
Sorry. do not have access to the remote router. But a similar config works with a different router. the only difference is the other one has 2 different physical interface instead of 1.
here we are trying with a Dot1q tunneling on the main interface.
Please find the HW details below:
System image file is "flash:c2600-itpk9-mz.122-25.SW8.bin"
Cisco 2650XM (MPC860P) processor (revision 0x100) with 105472K/25600K bytes of memory.
Processor board ID JAD070203JW (3476809370)
M860 processor: part number 5, mask 2
1 FastEthernet interface
32K bytes of NVRAM.
49152K bytes of processor board System flash (Read/Write)
.756 interface is connecting the router to the public and .50 is the new network which has the server connected and reach the remote end over the vpn.
Please let me know if you need more info.
