Cisco 2600 VLAN Rate Limiting
Jason Caron
I have a Cisco 2600 with multiple inside VLANs. How would I limit the usage on a specific VLAN?
Using 4250 out of 29688 bytes
version 12.1
no service single-slot-reload-enable
service nagle
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime
service timestamps log datetime msec localtime
service password-encryption
hostname Router
logging buffered 10000 notifications
logging rate-limit console 10 except errors
aaa new-model
aaa authentication login default local
enable secret 5 $1$xHlK$oMSqYq4aCPiNjCW1hD1gq.
username all
username W3stRivr password 7 132203475A5E55736A
username admin privilege 15 password 7 141E1C1F09167C78717A
clock timezone EST -5
clock summer-time EDT recurring
ip subnet-zero
no ip source-route
no ip finger
ip tcp selective-ack
ip tcp timestamp
ip tcp path-mtu-discovery
no ip domain-lookup
ip dhcp excluded-address 12.106.128.1 12.106.128.11
ip dhcp excluded-address 12.106.128.129
ip dhcp excluded-address 12.106.128.12 12.106.128.21
ip dhcp pool ChicagoRiverNorth_Apple
network 12.106.128.128 255.255.255.128
default-router 12.106.128.129
domain-name ChicagoRiverNorth_AP.com
dns-server 12.127.16.68 12.127.17.72
lease 0 12
ip dhcp pool ChicagoRiverNorth_EXHIBITION
network 12.106.128.0 255.255.255.128
domain-name ChicagoRiverNorth_EX.com
lease 0 1
no ip bootp server
ip cef
ip audit notify log
ip audit po max-events 100
class-map match-any http_hack
match protocol http url "*.ida*"
match protocol http url "*cmd.exe*"
match protocol http url "*root.exe*"
match protocol http url "*readme.eml*"
match protocol http url "*SAMPLE*.exe*"
match protocol http url "*sample*.exe*"
match protocol http url "*admin.dll*"
match protocol http url "*readme2.eml*"
match protocol http url "*httpodbc.dll*"
match protocol http url "*sample.eml*"
match protocol http url "*cool.dll*"
match protocol http url "*riched20.dll*"
policy-map mark_http_hacks
description policy map that marks inbound http hacks
class http_hack
set ip dscp 1
call rsvp-sync
cns event-service server
interface FastEthernet0/0
no ip address
no ip redirects
no ip unreachables
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0.10
description ***** For Exhibition Subet ******
encapsulation dot1Q 10
ip address 12.106.128.1 255.255.255.128
no ip redirects
no ip unreachables
interface FastEthernet0/0.15
description ***** For Apple Subnet *****
encapsulation dot1Q 15
ip address 12.106.128.129 255.255.255.128
no ip redirects
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 12.39.22.178 255.255.255.240
interface Serial0/0
description REMOVED DHEC108729.801..ATI - AT & T - (888-613-6330 Option's 211) - T1
ip address 12.125.174.142 255.255.255.252
ip verify unicast reverse-path
no ip redirects
no ip unreachables
encapsulation ppp
shutdown
service-policy input mark_http_hacks
no fair-queue
Giuseppe Larosa
Hello Jason,
you can do it by applying a service policy inbound to physical interface f0/0
access-list 121 permit ip vlan-source mask any
class-map vlanx_traffic
match ip address 121
policy-map limit_vlan_x
class vlanx_traffic
police 5000
int f0/0
service-policy input vlanx_traffic
Hope to help
Giuseppe
Joseph W. Doherty
Are you unable to use a service-policy under your FastE subinterfaces?
What kind of usage limitation did you want to implement? i.e. To, from or both to/from the VLANs; shaping or policing?
There is currently a 4.5 megabyte pipe coming into the router. I would like to limit one VLAN so that it can only use up to 3 MBPS of that circuit.
Would need much more in detail for suggesting what you might do.
However, in general, you often have a lot of control over bandwidth utilization when upstream of the circuit (outbound), but much, much less when downstream of the circuit (inbound). It's often easy to police inbound, but this often doesn't really guarantee inbound bandwidth utilization (again this is downsteam, not the same thing as 1st hop inbound).
