Which router can handle the bandwidth?
Scheffer
I have researched the hell out of Cisco's website and I'm still having trouble with making the right choice.
There will be 5Mbps links from the remote locations to the main location for a total of 20Mbps of WAN bandwidth being handled by the headend router. 2800 series routers at the remote sites and a 3825 as the headend would surely handle this (unless I'm mistaken).
But then I thought of scalability. There may actually be a need to increase the bandwidth up to 20Mbps per link in the future. I don't think the above choice of routers would handle this, but then I'm not experienced with WANs. So do I put a 3825 at each remote site and if so, what do I put at the main site?
Please please help or direct me to useful info. Thanks!
Collin Clark
I've attached the router performance guide. It should help you out.
paolo bevilacqua
Actually at the spokes you can use a 1841 and be safe. 20 mbps is not really much nowadays. Put a 3845 at the hub then upgrade if and when necessary.
Joseph W. Doherty
5 and 20 Mbps bandwidth? What kind of WAN bandwidth is this? If Ethernet, you might also consider small L3 switches, either the LAN variants, 3560 and 3750, or Metro Ethernet switches, e.g. 3750 Metro Series. These will easily handle much, much more bandwidth (multi gig), but you do need to insure the features they provide, which are often much more limited than a router's, suit your purposes.
The ISRs you've selected for hub and spokes at 20 (3825) and 5 (2800 - 2821?) Mbps, certainly fall within Cisco recommendations, but many of Cisco's latest routers can support more bandwidth than Cisco's recommendations. For instance, Paolo's recommendation of an 1841 should be good for your 5 Mbps spokes, and it's a modular router (an important consideration - and likely a reason he recommended this model). However, using Collin's reference, for 20 Mbps, you might want something with more performance than the 1841's 75 Kpps, especially since we often try to avoid running a software router routinely at or near 100% CPU load. You've already mentioned the 3825, Cisco recommended for half T3, making it the "safe" choice, but a 2851, or even 2821(?), might work well for you too. You didn't note what you might expect to upgrade your hub site to if the spokes are 20 Mbps, but up to about 100 Mbps, Paolo's suggested 3845, although more than the Cisco's recommendation for T3 bandwidth, I think, is likely to be fine.
Something to consider besides raw performance, is what might be added to the router. Besides CPU performance, the various 2800 models support different numbers of DSP slots, modules and module types. You might want to look over the various network modules, and if there are any you might want to use, you might consider choosing a 2800 with the number of and type of NME slots you might need.
[edit]
Cisco peformance recommendations:
"Q. What is the performance of the Cisco 1841?
A. The Cisco 1841 is a new-generation, best-in-class router platform designed to deliver multiple concurrent services at wire-speed performance up to single T1/E1/xDSL speeds."
2800 series, see Table 1 in: http://www.cisco.com/en/US/prod/collateral/routers/ps5854/prod_qas0900aecd80169bd6.html
3800 series, see: http://www.cisco.com/en/US/products/ps5855/prod_models_comparison.html
Thanks! All of your answers have been very helpful
