Cisco 2610 ADSL
scott.k.logan
I have a cisco 2610 with a WIC1-ADSL card, and the c2600-is4-mz version of IOS installed...
...My problem, I do believe, is in configuration. If I show interface adsl 0/0, it shows that there are packets being sent and received. On the BVI1 interface, they're only being outputted. I'm using Embarq (sprint) DSL, and they told me to use 8/35 for my vpi and vci...I have a static IP. What am I doing wrong? I can't ping the gateway from my router...?
--scott
21 Replies 21
Yeah, thats what I'm using now...its a "660 series" that I got from Embarq...
Ok, can you post a show dsl interface and show atm pvc x/y, and check if CRC errors on i/f are still increasing, perhaps a dsl fw issue. Config should be ok by now and should work.
Okay, here is the running config and the "shows" you wanted...
CNRouter Running Config:
version 12.3
hostname CNRouter
boot-start-marker
boot-end-marker
enable secret 5 $1$XXXXXXXXXXXXXXXXXXXXXXXXXXX
no aaa new-model
ip subnet-zero
ip cef
ip name-server 65.x.x.28
ip dhcp excluded-address 192.168.1.0 192.168.1.99
ip dhcp pool cnpool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 65.x.x.28
netbios-name-server 192.168.1.6
username cottsay secret 5 $1$XXXXXXXXXXXXXXXX
interface ATM0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0.1 point-to-point
ip address 65.x.x.117 255.255.255.0
ip nat outside
pvc 8/35
encapsulation aal5snap
interface Ethernet0/0
ip address 192.168.1.99 255.255.255.0
ip nat inside
full-duplex
interface Serial0/1
no ip address
shutdown
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 65.41.113.1
line con 0
line aux 0
line vty 0 4
password 7 XXXXXXXXXXXXXXXX
login local
end
CNRouter#show interfaces ATM 0/0
ATM0/0 is up, line protocol is up
Hardware is DSLSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 448 Kbit, DLY 4570 usec,
reliability 68/255, txload 1/255, rxload 1/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
23 maximum active VCs, 256 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input 00:00:01, output 00:00:37, output hang never
Queueing strategy: Per VC Queueing
5 minute input rate 1000 bits/sec, 2 packets/sec
170 packets input, 15577 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 51 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
5 packets output, 460 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
CNRouter#show interfaces ATM 0/0.1
ATM0/0.1 is up, line protocol is up
Internet address is 65.41.113.117/24
MTU 4470 bytes, BW 448 Kbit, DLY 4570 usec,
reliability 86/255, txload 1/255, rxload 1/255
Encapsulation ATM
214 packets input, 19446 bytes
0 OAM cells input, 0 OAM cells output
AAL5 CRC errors : 0
AAL5 SAR Timeouts : 0
AAL5 Oversized SDUs : 0
Question...what about NAT? Is NAT configured correctly? I did the "ip nat inside" and "ip nat outside", but I think I remember there being more to configuring NAT...
Another question...may seem dumb...but what is CRC? Is it bad?
--scott
I doubt this will ever work unless yo get a clean circuit - crc's are transmission errors.
Possibly an IOS upgrade can get you new FW - the one you have doesn;t even show what version is it, try show controllers.
I also think you shouls use a BVI config for this. For NAT you only miss "ip nat inside source list 10 interface bvi1 overload" and 'access-list 10 permit ip 192.168.1.0 255.255.255.0". bvi woulr be replace with atm0/0.1 for a routed 1482 encapsulation.
I would expect CRCs on an ADSL line. I mean, its DSL. Runs over house pairs. Goes a long way. Etcetera, and so forth.
I think the original config was probably right, I asked because I thought this might have been a business DSL routed sort of line, rather than a consumer line that had a modem on it before.
For that, it is certainly not correct anymore. Move the ip address back to a BVI, and delete it from the ATM PVC. After that, make sure that the encapsulation on the interface actually changes to AAL5 and RFC1483. Right now, it is AAL2. Then, verify the ATM interface is in the bridge table (show bridge 1) and try to ping the default gateway from the router, sourced from int BVI1 (ping x.x.x.x source bvi1).
If all that works, then you can add the nat stuff back. You were just missing an access list that matches your inside lan subnet.
NS
Alright, please look at the other post for my new config, but I still can't ping...even with the 'source bvi1' on the tail. Here's my show bridge 1...it looks right to me.
CNRouter#show bridge 1
Total of 300 station blocks, 299 free
Codes: P - permanent, S - self
Bridge Group 1:
Address Action Interface Age RX count TX count
0030.8803.459b forward ATM0/0 3 37 0
...and if you'll notice in the show int for the atm, it shows AAL5 AND AAL2...
thanks,
--scott
Alrighty, so here's my new configuration:
version 12.3
hostname CNRouter
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxxxxxx
no aaa new-model
ip subnet-zero
ip cef
ip name-server 65.41.112.28
ip dhcp pool cnpool
dns-server 65.41.112.28
username cottsay secret 5 xxxxxxxxxxxx
bridge irb
interface ATM0/0
no ip address
bridge-group 1
pvc 8/35
ip nat inside
full-duplex
interface Serial0/1
no ip address
shutdown
interface BVI1
ip address 65.41.113.117 255.255.255.0
ip nat outside
ip nat inside source list 10 interface BVI1 overload
no ip http server
ip classless
access-list 10 permit 0.0.0.0 255.255.255.0
line con 0
line aux 0
line vty 0 4
password 7 xxxxxxxxxxxxxxxxxx
login local
end
reliability 226/255, txload 1/255, rxload 1/255
Last input 00:00:00, output 00:02:15, output hang never
342 packets input, 35745 bytes, 0 no buffer
0 input errors, 172 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
17 packets output, 1258 bytes, 0 underruns
CNRouter#show interfaces BVI 1
BVI1 is up, line protocol is up
Hardware is BVI, address is 0000.0cf0.ffe5 (bia 0004.9a8f.c920)
MTU 4470 bytes, BW 448 Kbit, DLY 5000 usec,
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/0 (size/max)
0 packets input, 0 bytes, 0 no buffer
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
11 packets output, 660 bytes, 0 underruns
Now here's something interesting...I tried the show controllers, and I got four of these on the console...
*Mar 2 09:51:27.531: ASSERTION FAILED: file "../les/if_dslsar_util.c", line 382
That doesn't look good...bad IOS image? Bad firmware? I have no idea...?
--scott
