Cisco 2800 Password Recovery Failed
Maddin B
I wanted to do with my Cisco 2800, a password recovery.
I have read the instructions and Cisco just came up at six.
Complete these steps in order to recover your password:
  1. Shut down the router.
  2. Remove the compact flash that is at the back of the router.
  3. Power on the router.
  4. Once the Rommon1> prompt appears, enter this command:
    confreg 0x2142
  5. Insert the compact flash.
  6. Type reset.
BUT
I had forgotten to plug the flash card.
And now comes via console hieroglyphics only
Ivan Shirshin
Try to change the speed in terminal and see if that helps.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
