cisco 2800 reload get into rommon mode,but Cannot reply
weijun.duan
my  Troubleshooting:
s1:rommon>confreg
s2:
do you wish to change the configuration? y/n  [n]:  y
enable  "diagnostic mode"? y/n  [n]:
enable  "use net in IP bcast address"? y/n  [n]:
disable "load rom after netboot fails"? y/n  [n]:
enable  "use all zero broadcast"? y/n  [n]:
enable  "break/abort has effect"? y/n  [n]:
enable  "ignore system config info"? y/n  [n]:
change console baud rate? y/n  [n]:
change the boot characteristics? y/n  [n]:  y
enter to boot:
 0 = ROM Monitor
 1 = the boot helper image
 2-15 = boot system
    [0]:  2
S3:ROMMON> Reset
No progress
S4:ROMMON>DIR FLASH:
c2800nmc-spservicesk9-mz.150-1.M7.bin
s5: boot flash:c2800nmc-.bispservicesk9-mz.150-1.M7.bin
No progress
but,found.
Readonly ROMMON initialized
AUTOBOOT entry: NVRAM VALUES: bootconf: 0x2, autobootstate: 0
autobootcount: 0, autobootsptr: 0x0
Autoboot state 0 BOOT variable returns: cptr = 0x0
autoboot about to execute command buffer: "boot flash:"
cptr = 0x0
program load complete, entry point: 0x8000f000, size: 0xcb80
loadprog: error - Invalid image for platform
e_machine = 213, cpu_type = 135
boot: cannot load "flash:"
autoboot: returned from boot command
AUTOBOOT exit: NVRAM VALUES: bootconf: 0x2, autobootstate: 2
autoboot: issue do_reset()
SOS !!!!!!!!!!!!!
Thank you very much.
weijun.duan
Supplement:
flash--------format
I would suggest to boot from network (tftp) with IP_BASE image.
After you will be  able to troubleshoot your flash (if it's the cause).
