Cisco 2801 routing issue
wanstor
Hi all
We have a cisco 2801 with 2 x sdsl wics and 1 x adsl wic. These distribute traffic based on port group. This ahs been working fine up until last week. The connection randomly stops sending traffic out the external interface for a few minutes and then carries on as normal. The abndwidth is not being maxed out as far as i can tell and the CPU on the router is also not maxing out. Any help wll be much appreciated
paolo bevilacqua
Reloading router helps ?
Kimberly Adams
Level 3
Level 3
Does it start working again by its self?  Does the log files show anything?  Are you seeing a lot of connections or xlates (something to indicate a virus or malware)?
Cheers,
Kimberly
Thanks and Cheers! Kimberly Please remember to rate helpful posts.
