10-13-2015 11:29 AM - edited 03-05-2019 06:57 AM
I have a couple 2811 routers, one in storage, one in production. I'll be removing the wic from the storage unit to the production router. Shouldn't the router automatically 'pick-up' the new card?
wic == 1DSU-T1 v2
IOS 12.4(23b)
Solved! Go to Solution.
10-13-2015 12:01 PM
Hi Christopher,
Yes your router should see tye card BUT - the 2811 does not support on line module insertion.
So make sure you power down 1st.
Alex
10-13-2015 11:54 AM
Hi Chris,
No, online insertion and removal (OIR) of modules(NME or HWIC slots) is not supported on the Cisco 2800 Series.
Hope this helps.
Rajneesh
10-13-2015 12:11 PM
Thanks for the reply.
10-13-2015 12:01 PM
Hi Christopher,
Alex
10-13-2015 12:11 PM
Yep. Power off first....Thanks!
