Cisco 2811 + High CPU Untilization while heavy traffic
TCMC_cisco
We are having issues with our Cisco 2811 when there a lot of traffic on the device. Usually the router is down around 5%-10%. Total traffic might be around 2.0 MB. This is a router we are using at a remote campus. We do HD video conferencing every friday. We have a 10 MB internet connection that has our VPN connection to the main campus on it. While doing these VTC, the totall traffic is about 6 MB. The CPU Utilization then rises to approx 75% cause call issues and loss of sound. With another test with no one using the connection for anything else the utilization went up to 35%. The router has 128 MB Ram in it. What does anyone suggest I should look at to see if there is anything I can do to make this work better. Does the router need more RAM or do we need a larger internet pipe. Again we only have issues when we are under a heavy traffic load.
7 Replies 7
Hello
how much is your peak usage in terms of packets per second? You can get this
value and compare it to this figures:
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
Beside, if you have multicast traffic you could experience higher cpu usage since that
might be process switched.
Kind regards
Francesco
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 10-Oct-08 00:05 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
WB-2811-Voice uptime is 10 weeks, 1 day, 22 hours, 18 minutes
System returned to ROM by reload at 17:11:18 EDT Tue Aug 14 2012
System restarted at 17:13:46 EDT Tue Aug 14 2012
System image file is "flash:c2800nm-advipservicesk9-mz.124-22.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 239616K/22528K bytes of memory.
Processor board ID FTX1248A20Y
3 FastEthernet interfaces
1 terminal line
1 Channelized (E1 or T1)/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
1 cisco Integrated Service Engine(s)
   CCA NME-NAC-K9 4.9.0 in slot 1
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
TCMC_cisco
Only about 2000 pkts/sec when the issue is going on.
paolo bevilacqua
Post show run, show ver, show int.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
"VPN"?  High CPU loading might be due to IP fragmentation of video packets.
The call and sound quality issues might be related to transient congestion if you're not using QoS to manage your bandwidth or you share WAN bandwidth with multiple VPN tunnels and/or "native" Internet traffic.
WB-2811-Voice#show interface summary
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface              IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
  FastEthernet0/0          0     0    0     0     0    0     0    0    0
* FastEthernet0/1          0    52    0     0 565000  135 1259000  160    1
* FastEthernet0/1.600      -     -    -     -     -    -     -    -   -
* FastEthernet0/1.601      -     -    -     -     -    -     -    -   -
* FastEthernet0/1.602      -     -    -     -     -    -     -    -   -
* FastEthernet0/1.2884     -     -    -     -     -    -     -    -   -
* FastEthernet0/1/0        0     0    0    16 189000   11     0    0    0
* In1/0                    0     0    0     0  2000    1  3000    2    5
  NVI0                     0     0    0     0     0    0     0    0    0
* SSLVPN-VIF0              0     0    0     0     0    0     0    0    0
* Tunnel0                  0     0    0 142610     0    0     0    0    0
NOTE:No separate counters are maintained for subinterfaces
     Hence Details of subinterface are not shown
TCMC_cisco
Joseph,
     Inisitially it was sharing the bandwidth with the VPN Tunnel and "Native" Internet Traffic. I moved it over to our WAN connection. Our ISP basically gives us a VLAN to route traffic to our campuses, however... Phones, Printing, File Servers, and VTC traffic all move over that link also. "Native" Internet traffic goes out a separate port. Hoever it is only a 5MB Link.
* FastEthernet0/1          0    52    0     0 4568000  848 5815000  907    1
This is an example of what I get for this port with Show interfaces summary. The TXBS is over the 5MB.
