cisco 2811 router LAN ports
shaikh ibrahim
Hi ,
    i would to ask that ,how many extra interface port can be plugged in to the 2811 router ,there are 2 fixed FE port on this router and i have 3 connection
i.e one mpls link , one internet link  and one sip trunk .. some body confirm me  that i can insert module in 2811 ? in order to solve this problem
Thankyou in advance..
SHIB
Hi Ibrahim,
I prefer to buy a HWIC-4ESW card because you'll never push over a 100Mb of traffic through a 2800 series device.
If you are satisfied then please mark this question as answered.
please rate if it helps.
5 Replies 5
Sandeep Choudhary
Hi Ibrahim,
If you insert a HWIC-4ESW card then you will get four more fastethernet ports:
FE0/0/0
FE0/0/1
FE0/0/2
FE0/0/3
is this you wanted to know. or somethingelse?
Please rate if it helps.
yes Thankyou , but one more thing  which type of card for sip trunk should i use? i mean GE or FE?...
As per my knowledge you have to use GE for the SIP trunk.
So which card model .i will order??
Hi Ibrahim,
