Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco 2811 router
husseinmuneer
Dear all,
We have a cisco router 2811 so it has 2 IOS one is default IP- base and the other is  c2800nm-ipbasek9-mz.124-20.T1 to support the E1-PRI card.
The router working fine then anfter 2-5 hours the service go down and after we access by Hyper temial we found it in the ROMMON1, we do switch off switch one then the router load the IOS and working well. this problem happen 2-4 times a day.
WHat do you think the problem ?
Regards.
Leo Laohoo
Boot the IOS and post the output to the following commands:
1.  sh version
2.  dir flash:
In addition to the suggestion from Leo I would suggest that you make sure that console logging is enabled to at least info level (if not debug) and connect a terminal to the console port. Then look to see if any console messages are generated that might show events as the router went into rommon.
Rick
Rick
