help on bgp config
prashantrecon
on router name as chic there are two links one is for outgoing and one for incoming.ie  for local prefernce 600 is used for outgoing and 300 for
incoming.
int fa0/1
ip add          202.124.x.19
int fa0/0
203.x.x.29
router bgp 4xxx
neighbor 202.124.x.x remote-as 95xx
neighbor 125.17.x.x  remote-as 18xx
neighbor 202.124.x.x route-map RELIANCE-IN in
  neighbor 202.124.x.x route-map RELIANCE-OUT out
neighbor 125.17.x.x route-map AIRTEL-IN in
  neighbor 125.17.x.x route-map AIRTEL-OUT out
  no synchronization
  network 203.x.x.x/24
ip prefix-list DEFAULT seq 5 permit 0.0.0.0/0
ip prefix-list AIRTEL-OUT seq 5 permit 203.x.x.0/24
ip prefix-list RELIANCE-OUT seq 5 permit 203.x.x.0/24
route-map AIRTEL-IN permit 10
match ip address prefix-list DEFAULT
set local-preference 300
route-map RELIANCE-IN permit 10
set local-preference 600
On other router name as sa only one link is terminated.for incoming and outgoing
Note router chic and sa are in same company but there are not connected to each other.
router chic is used for diffrent vlan and router sa is used for diffrenrt vlan but incoming traffic is adversiteed as
203.x.x.x on both router.
Problem- when router sa is turned on trffic coming at router chic is geeting affected.sudeen all the tunnels are geeting affected.
browsing also geeting affected.
Vivek Ganapathi
Level 4
Level 4
Hi Prashanth,
Not clear about the setup. Is it possible to provide a topology ?
I have attached the set up
