08-09-2011 04:21 AM - edited 03-04-2019 01:13 PM
I have a Cisco 2851 that is not booting correctly. It was working fine in one evironment and I removed it and reloaded it and went into rommon to get by the password and clear the config by setting config register to 0x2142. Thats all I did since it was last working fine.
Now, when I boot it up, I immediatly see a bunch of:
And that is all I see. I left it over night and it was still incrementing them and did not boot IOS or rommon. The System power light is blinking green rapidly. I have tried pressing the break key and can't get into rommon.
What is wrong and what can I do to fix it? Thanks.
Solved! Go to Solution.
08-09-2011 07:25 AM
Check the baud rate
Sunil
Pls rate the post if you find the content useful.
08-09-2011 07:25 AM
Check the baud rate
Sunil
08-09-2011 09:33 AM
That was it... I must have typoed the config register because it should have been 9600....
Thanks!
