Cisco 2900 router msg: "0 subnet is currently in the pool"
roncro
Level 3
Level 3
I am setting up a Cisco 2900 router with the dhcp service running/on.
Somehow, on the wireless it is handing out adresses in the '0 subnet',  like 192.168.0.x and only addresses like that.
I am using an origin file,  all host entries are in 192.168.1.0 bound to their MAC address.
When I check the pool,  this is what I see:
Pool VLAN1 :
Utilization mark (high/low) : 100 / 0
Subnet size (first/next) : 0 / 0
Total addresses : 28
Leased addresses : 28
Pending event : none
0 subnet is currently in the pool :
Current index IP address range Leased addresses
192.168.1.37 192.168.1.37 - 192.168.1.37 1
I tried excluding  those ip addresses with:  "ip dhcp excluded-address 192.168.0.1 192.168.0.254"
but it just seems to ignore that. I tried setting the network like "network 192.168.1.0 255.255.255.0 but I get an error saying "you can't do that with the origin file command.
any ideas why dhcp hands out  addresses in the0 subnet?
(I did see a subnet command in the dhcp-config like :
(dhcp-config)#subnet ?
prefix-length Designate subnet allocation unit size;   but have no idea what that does.
thanks,
Ron
47 Replies 47
looking at the output you have posted:
--> 0 subnet is currently in the pool
There seems to be some misconfiguration. Can you post the full running config, as well as the origin file you are using ?
Yes I can definitely do that.  (I also seem to have a problem, a msg that says;
%IP-4-DUPADDR: Duplicate address 19.168.37.1 on GigabitEthernet0/1.37 by xxxx.xxxx.xxxx; wonder what happened there.
I'll post the running config an origin file too  (I have two, but probably the same problem)
thanks!!
Ron
PS:  I thought I posted this late last night, apparently it got autosaved and not sent.  sorry.
#show run
Building configuration...
Current configuration : 4006 bytes
! Last configuration change at 06:59:40 UTC Fri Apr 24 2020 by admin
version 15.4
service password-encryption
hostname Charon
boot-start-marker
boot-end-marker
enable secret 5 $1$Y6Ap$foIYqVqbcci.b9/iOKKVt/
no aaa new-model
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.2.1 192.168.2.5
ip dhcp excluded-address 192.168.37.1 192.168.37.5
ip dhcp pool VLAN1
origin file tftp://192.168.2.8/dhcp/static-bindings-subnet-1
default-router 192.168.1.1
dns-server 192.168.1.1
ip dhcp pool VLAN2
origin file tftp://192.168.2.8/dhcp/static-bindings-subnet-2
default-router 192.168.2.1
ip domain name localdomain
ip host cisco-ap6.localdomain 192.168.1.6
ip host C2960s-north.localdomain 192.168.1.2
ip host cisco-ap1.localdomain 192.168.1.11
ip host cisco-ap5.localdomain 192.168.1.5
ip host cisco-ap9.localdomain 192.168.1.19
ip host charon.localdomain 192.168.1.1
ip host zoneminder.localdomain 192.168.2.8
ip host waves.localdomain 192.168.1.117
ip host trotter68.localdomain 192.168.1.110
ip host trotter67.localdomain 192.168.1.109
ip host cuda.localdomain 192.168.1.116
ip host seismo.localdomain 192.168.2.4
ip host cnc.localdomain 192.168.1.115
ip host wintrotter.localdomain 192.168.1.106
ip host picopod.localdomain 192.168.1.107
ip host wemo.localdomain 192.168.2.2
ip host Samsung-HDTV.localdomain 192.168.3.3
ip host picoscope.localdomain 192.168.3.37
ip host cisco-ap7.localdomain 192.168.37.17
ip host cisco-ap8.localdomain 192.168.37.18
ip host cisco-ap2.localdomain 192.168.37.12
ip name-server 75.75.75.75
ip name-server 75.75.76.76
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO2911/K9 sn FCZ192771UU
username admin password 7 1500085A550A3F373D3D342F1A5441
username wwwadmin privilege 15 password 7 061118365E4D5F48251B130500
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip helper-address 192.168.1.1
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1.1
interface GigabitEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.37
encapsulation dot1Q 37
ip address 192.168.37.1 255.255.255.0
ip directed-broadcast
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1/0
no ip address
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
interface GigabitEthernet0/1/3
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip dns view default
domain list localdomain
ip dns server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip nat inside source list 102 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip 192.168.2.0 0.0.0.255 any
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 105C0A4F54370618190A2B262D7B64
login local
transport input ssh
line vty 5 392
password 7 131714445A2C10393E2A293E3C7144
login local
transport input ssh
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server time.nist.gov
end
the origin file:
*time* Apr 20 2020 5:11 PM
*version* 3
!IP address Type Hardware address Lease expiration
! Work stations and servers in subnet 192.168.1.0
192.168.1.37 /24 1 8C8E.F269.BD3D Infinite
192.168.1.64 /24 1 146B.9CA6.CE60 Infinite
192.168.1.65 /24 1 146B.9CA6.AEEC Infinite
192.168.1.66 /24 1 0C8C.2442.1E16 Infinite
192.168.1.67 /24 1 146B.9CA8.0326 Infinite
192.168.1.68 /24 1 146B.9CA7.F73A Infinite
192.168.1.69 /24 1 146B.9CA6.9F8C Infinite
192.168.1.70 /24 1 146B.9CA7.F72A Infinite
192.168.1.71 /24 1 146B.9CA8.249F Infinite
192.168.1.72 /24 1 146B.9CA8.24C6 Infinite
192.168.1.73 /24 1 146B.9CA7.3123 Infinite
192.168.1.77 /24 1 0015.2B06.A7E3 Infinite
192.168.1.104 /24 1 0021.5C58.2995 Infinite
192.168.1.105 /24 1 001C.BFA0.591C Infinite
192.168.1.106 /24 1 0019.B96D.7C91 Infinite
192.168.1.107 /24 1 0012.7B46.8E0B Infinite
192.168.1.108 /24 1 2477.03c6.6f74 Infinite
192.168.1.109 /24 1 D4BE.D975.9B02 Infinite
192.168.1.110 /24 1 ECF4.BB39.7B50 Infinite
192.168.1.111 /24 1 3CA9.F49F.1B9C Infinite
192.168.1.114 /24 1 0019.B971.6CB6 Infinite
192.168.1.115 /24 1 0025.649C.28E7 Infinite
192.168.1.116 /24 1 1803.7329.A583 Infinite
192.168.1.117 /24 1 BC30.5BB0.80D9 Infinite
192.168.1.137 /24 1 0811.9643.2DE4 Infinite
! toys
192.168.1.235 /24 1 f4a9.9783.3d31 Infinite
192.168.1.236 /24 1 d0c5.d350.aaad Infinite
192.168.1.237 /24 1 D8C4.6A82.1704 Infinite
file and config look okay. You could try and change the origin file to something that resembles the client address rather than the hardware address. So nstead of:
you would prepend a '01' to the MAC address:
192.168.1.37 /24 1 018C.8EF2.69BD.3D Infinite
Hello Georg,
first of all, thank you for looking through that config.
I can definitely change that  from hw adress to client ID.  I am wondering though, is it a warning?  or an error?
Whenever the router loads that file it says:
abcd bytes
[ok]
Also,  what does the error/warning message exactly mean?
Does it mean,  there are no subnets in the pool? (which I think would seem weird)..  or?  is the 192.168.0.0 subnet in the pool?
thanks!!
Ron
(oh and I found the offending duplicate ip address).
so I changed one of the origin files.
What I get now is:
65508 subnets are currently in the pool :
how are there 65508 subnets in that pool?
I changed the entries to what you suggested:
my bad, I gave you a wrong sample. The entries should look like this (id instead of 1):
192.168.1.37 /24 id 018C.8EF2.69BD.3D Infinite
I actually wondered about that,  but since I am the rookie, I didn't say anythink.
thanks!
Ron
ok,  so I changed that, and ended up with the old situation again:
Pool VLAN1 :
just to be sure, does your file have the
*end*
denominator ?
yes it does have the *end*  at the end of both files.
Hello
Possible another dhcp server device active that is  allocating addressing in that range.
Check the dhcp server address in the client allocation and then check its arp address for that ip, The trace that mac- address to the source of the dhcp server.
Another way would be to enable dhcp snooping and trust ONLY the uplinks to you known dhcp server.
Kind Regards
Paul
Hello Paul,
thanks for that suggestion.  Actually nothing that is powered on on the network does dhcp. (what would be the best way to trace that?  I used  'show ip arp | include 192.168' That didn't show anything unexpected.
All but 5 machines, 2 of which are powered on) use dhcp.  All the wireless stuff I have does,  but  I don't even see anything broadcast coming out of the "wireless AP trunks" to begin with
I changed the static-bindings file from HW addresses to  the ID, but that changed the  0 value to65,000-something which surprised me.
thank you!
Ron
Hello
On a client like a windows pc if you have one
ipconfig /all
This will show you the ip address of the dhcp server
Ping that is address and then see if you get an arp entry for it
Kind Regards
Paul
I have all linux machines,  but yes I can see the arp.
