Cisco 2901 set as DHCP unable to ping to internet
j.pewarski
I need another set of eyes on my config. I am trying to set up my router for a basic connection for the time being. I set my gig 0/0 port to dhcp I see traffic being sent and recieved but I can not ping 8.8.8.8. I am connected to a basic comcast modem from 0/0 I have also tried setting gig 0/0 to 100 full. I do have IP routing enabled. I believe I have my acl's configured correctly. I am wondering at this point if I need a static block of IP's from comcast. Can someone help me please. Thanks!
hostname vpn-router-2901
username ****** password *****
enable secret *****
login block-for 45 attempts 2 within 45
login on-failure log
login on-success log
SSH CONFIGURATION
ip domain name yourdomain.com
crypto key gen rsa gen mod 1024
ip ssh version 2
line vty 0 4
login local
logging synchronous
transport input telnet ssh
line vty 5 15
login local
logging synchronous
line con 0
login local
logging synchronous
SERVICES CONFIGURATION
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
IP ROUTING CONFIGURATION
ip route 0.0.0.0 0.0.0.0 dhcp
ip name-server 75.75.75.75 75.75.76.76
INTERFACE CONFIGURATION
int g0/0
ip address dhcp
ip nat outside
ip access group 110 in
ip access group 110 out
speed auto
duplex auto
logging event link-status
int0/1
ip address 10.38.241.160 255.255.255.0
SNMP CONFIGURATION
access-list 110 permit icmp any any echo
access-list 110 permit icmp any any echo-reply
access-list 110 permit udp any any eq domain
access-list 110 permit udp any eq domain any
access-list 110 permit tcp any any eq domain
access-list 110 permit tcp any eq domain any
access-list 110 permit ip any any
14 Replies 14
johnlloyd_13
Level 9
Level 9
hi jeffrey,
you'll need to specify your inside NAT interface and ACL.
could you post show run and show ip route output?
I will I am not connected now I will post it tomorrow. Shouldent I still be able to ping even though I don't have anything connected to g 0/1? I did put ip nat inside on my running config. As for show IP route nothing is in the routing table. Do I still need dynamic routing protocols? I wouldent assume so if im just trying to ping out from the router?
yes, you should be able to ping IP address or hostname from your 2901.
as for the blank routing table, make sure your 2901 can ping the ISP modem/router and ISP device has a similar route back.
I tried that as well I could not get to the public IP. I tried two different IP's as my gateway one from whatismyip.com, another from when I connected the laptop directly to the modem, and used the public gateway address that showed into my laptop and then I finally did 0.0.0.0 0.0.0.0 dhcp and still was not able to ping 8.8.8.8 or the modem. If it helps my cisco 0/0 interface is directly connected to my ISP modem. Are you telling me Comcast has to do something on their end to have a route back to me. Would a static ip block from my ISP eliminate these issues?
you'll need to contact your ISP to check your link if it's working and what kind connectivity you've got (static or dynamic IP).
Hello Jeffery,
Just let the interface gig0/0 negotiate with the modem ( providing the modem is dhcp enabled)  without acl's or NAT applied and then  if successful the apply your restrictions on top.
FYI-  your acl is allowing everything in /out anyway and the nat statement hasn’t any inside interface or acl to work with.
res
Paul
Kind Regards
Paul
j.pewarski
here is my running config.
Current configuration : 4753 bytes
! Last configuration change at 18:02:31 EST-DST Fri Jan 11 2013 by sunkaras
version 15.1
hostname vpn01.srisun.com
boot-start-marker
boot-end-marker
no shell processing
logging buffered 51200 warnings
enable secret 4 Z6EYME8qXPkweZS1QX2UmrWLnfGrG0PYug0iNqpUDD.
no aaa new-model
clock timezone EST-DST -5 0
clock summer-time EST-DST recurring
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip name-server 75.75.76.76
crypto pki trustpoint TP-self-signed-2351994672
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2351994672
revocation-check none
rsakeypair TP-self-signed-2351994672
crypto pki certificate chain TP-self-signed-2351994672
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32333531 39393436 3732301E 170D3132 30373238 30343239
  34315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 33353139
  39343637 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009247 E73A291D 82AD0583 477BCD74 3F7B441C 8B614EF1 9B89E99E BD770CEE
  D1308901 C36B3AB2 5DCCEB78 D479E052 9B2F177B 7EAC02D3 674AAAE8 617E7139
  26EF0C91 D7B20295 CE0D7AB3 2A9FF14E CFE72224 92C010F8 A86427CF 0A8DB204
  7914F1FC 467A6D11 956F2306 2A48C711 B5326979 755D37C7 EF53F4D6 5F7A862D
  D0970203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1429F302 88B5FBE3 725FEA26 44957A4E 683E4955 A0301D06
  03551D0E 04160414 29F30288 B5FBE372 5FEA2644 957A4E68 3E4955A0 300D0609
  2A864886 F70D0101 05050003 81810026 48B07A7F 70BDCAAC E84B1445 ADC1A5D1
  89D9747E D32C2974 BF65836C 641EDF30 97DD6EE0 63312B78 B4527F9D CF7D8B40
  451DE82A 9D481AC3 E4E69B79 2CF884D5 35A7D5BB 8A5EA9A9 ABAEB304 77AF4244
  AF6381F3 ECB44792 5F9DB0CE A79DF572 7E12913F 4DDD733D 76CAA229 CC4EC17F
  20391483 2E005DCB A0D6926C 052A02
        quit
license udi pid CISCO2901/K9 sn FGL163026HF
username sunkaras password 7 05070704241D175E41
ip ssh version 2
interface Embedded-Service-Engine0/0
ip address dhcp client-id GigabitEthernet0/0
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address dhcp
ip access-group 110 in
ip access-group 110 out
ip information-reply
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
interface GigabitEthernet0/1
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
banner motd ^C
                 =   UNAUTHORIZED ACCESS PROHIBITED   =
        You have reached a confidential and proprietary computing
        network. Unauthorized access is unlawful and may result in
        disciplinary action and / or legal proceedings. Any access
        to this system may be monitored.
^C
line con 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
logging synchronous
login local
line vty 5 15
access-class 23 in
privilege level 15
logging synchronous
login local
scheduler allocate 20000 1000
ntp server 128.102.16.2
ntp server 192.43.244.18
end
j.pewarski
Gateway of last resort is not set
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.38.241.0/24 is directly connected, GigabitEthernet0/1
L        10.38.241.160/32 is directly connected, GigabitEthernet0/1
j.pewarski
the connection is DHCP, and I removed my acl and nat just to test. I still can not get any pings accross. Would this be a ISP Problem at this point?
I would check with your ISP to see if that modem is set as a dhcp server, and also query what mode it currenty running.at.
bridged = layer2- - PPoE settings are controlled by modem
router. -Layer 3 - need to configured PPoE settings on your router
res
Paul
Kind Regards
Paul
can you do this on G0/0:
ip address dhcp client-id G0/0
shut
no shut
then verify you got infos from DHCP: sh ip int br and sh ip route
if it still ain't working then shut/no shut the interface  while having this debug on: debug dhcp detail
send the logs to the buffer before no shutting the interface:
logging on
logging buffered 1000000 debug
do clear log
then do sh log to see the debug output
Regards.
Alain
You have defined which interfaces to NAT in which direction but have not defined which traffic TO NAT.
Also, make sure the access list is removed from gi0/0. That acl is blocking dhcp.
j.pewarski
hi everyone. I dont have access to the router until moday night, so I will do all of the above you guys listed last night and look into the PPoe that pdiver suggested. When I plug a laptop into the modem I can get a dhcp address. I also see packets being sent and recieved on my g 0/0 when I look at the interface.
