Cisco 2911 and NAT Configuration
hodgson.c
I have a Cisco 2911 router that I am trying to edit/add to the NAT Configuration through Cisco Configuration Professioanl.  The issue I am having is when I go there to edit an exisiting entry or add a new one none of the buttons are working.  I can click on them but nothing happens.
I am new to the whole configureing and working with a routre so any help would be great.
Chris
AhmedSonba
Hello Chris,
I will be rather hard to troubleshoot the Cisco Configuration Professional issue for us , but describe what you want to achieve and we can help you and show how to do it with the command line , You will fine it rather easy.
for starters please find more information about how to do NAT on with the Command Line below
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
Hope it will help
Ahmed Sonba
What I want to achieve is to change the route my users use when they come into the term server.  Right now there is a NAT record that looks like the following
Oringinal Address 192.168.1.28(3390) Translated Address 204.101.189.196(3390)
I need to change that Original Addres to the new term server so that users connect to it instead of the old server.
I hope that make sence, if you need any more information I can provide it.
Hello Chris,
I will write an example of how to do the required NAT Transultation
First Access List for the port number 3390
access-list 100 permit udp 10.1.31.10 "your Original Addres"  host  204.101.189.196 eq 3390
Than it comes to the NAT commands
ip nat inside source list 100 interface " your out side nat interface" , EX fastethernet 0/1 "  overload
and at the end the
ip nat outside
on the interface with the WAN connection
and the
ip nat inside
on the interface with the LAN connection
please refer to the following link for more information about NAT
http://www.cisco.com/en/US/technologies/tk648/tk361/tk438/technologies_white_paper09186a0080091cb9.html
Hope it will help
Ahmed Sonba
