WAN Redundancy
angel-moon
Level 3
Level 3
I know that with Serial interfaces I can do MLPPP but so far what I have seen says that the serial interface get a "no IP address" and joined to the multilink bundle which has the IP address.  What can I do to bundle something like a cable Internet connection and  DSL or metro E?  All would have an Ethernet handoffs but all of these types of circuits also require, I think, and IP address.
Goal would be to load share across the circuits or second choice, to have  the backup link activate as soon as the primary link goes down.
Thanks in advance!  All replies rated.
AhmedSonba
Hello
Yes you can achieve that by using static routes with object tacking, the example below will show you
more details
Normally  you will need two default routes one that points to the main ISP "Lets say metro ethernet "  and  the other points to the second back ISP DSL " than you have a  link with object tracking on  the main ISP normally you should give the main route lower  administrative distance
for example :
ip sla 1
icmp-echo 8.8.8.8 source-interface FastEthernet0 " interface with the main ISP"
timeout 500
threshold 500
frequency 3
ip sla schedule 1life forever start-time now
track 1 ip sla 1 reachability
delay down 10 up 20
ip route 0.0.0.0 0.0.0.0 10.10.10.1 track 1 " Main route"
ip route 0.0.0.0 0.0.0.0  192.168.2.1  7 "Backup route"
In this case the main route to the ISP went down the backup route will take over and be installed in the routing table
also You will need to add a static route for the Google DNS that point’s to the first ISP
Like the following:
IP route 8.8.8.8 255.255.255.255.255 1.1.1.1
Please refer the following link for more information
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
Hope this will help
Ahmed Sonab
AhmedSonba
Hello
more details
for example :
ip sla 1
timeout 500
threshold 500
frequency 3
delay down 10 up 20
Like the following:
Hope this will help
Ahmed Sonab
