cisco 2911 occasionally crash.
zhendong xu
Our company has a cisco 2911 for edge router .
It's version
c2900-universalk9-mz.SPA.150-1.M5.bin.
It only has
nat, default route and some access-list
for it, .
recently  it occasionally crash, about once / two months.
could some help have a look at the crashinfo file .
Why the router crash?
Thanks.
Leo Laohoo
@zhendong xu wrote:
%TCP-2-INVALIDTCB: Invalid TCB pointer: 0x31A1D664 -Process= "HTTP CORE"
Disable HTTP server.
How big is the WAN link?
What other services does this router do, FW or UC?
By the way, the router is using IOS version 15.0(1)M5.  If I enter the IOS version into the IOS Software Checker, THIS is the result of known security vulnerabilities this router is exposed to.
9 Replies 9
Leo Laohoo
Not sure how "recent" but the crash info file was generated on 17 October 2021.
By the way, the password is in plain text.
What you meant by crash?
is it restarting or shutting down?
check the logging details for identify the reason for restart or shutdown.
Good luck
KB
the router restart and generate a crashinfo  file in the router's flash
Leo Laohoo
thanks.
i will disable the http server.
The wan bandwith is only 50M.
there is no other service.
only
NAT, default route, and some access-list.
@zhendong xu wrote:
thanks.
only NAT, default route, and some access-list.
Let me repeat my first response:  The crashinfo attached contains a password in plain text.
Sanitize it before uploading for every man-and-his-dog to see.
i have removed the plain password.
thanks
just out of curiosity, how did you resolve this ? What was the issue ?
marce1000
 - Have a go with latest advisory release :  https://software.cisco.com/download/home/282774227/type/280805680/release/15.7.3M8  , check if that can help.
 M.
