Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco 2921 Gi0/1 is not coming up
umesh.chowdhary
Hi all ,
I need someone help  to figure out why Cisco 2921 Gigaethernet 0/1 is not coming up ? I also tried to connect the interface to another SWITCH with no joy.
ME3400 (ISP's switch)<-------------MPLS link--------------> Cisco 2921 Gi0/1 >>>>>>>>>>Port not coming up
I tried connection between ME3400 (ISP's switch) and spare switch and the INTERFACE of spare switch was in UP/UP state .
Troubleshooting I did so far on Interface Gi0/1
1> Changed ths speed/duplex manually and revert it back to auto
2>diable keepalive
3> Tried differnet LAN cable with no luck
4> Please see HIGHLIGHTED part (in red colour) of "Show controller Gi0/1" command
I am pasting some of the SHOW command output , can someone please assist me  ?
R2921_MMP#sh run int gi0/1
Building configuration...
Current configuration : 116 bytes
interface GigabitEthernet0/1
ip address 10.90.10.2 255.255.255.252
duplex full
speed 100
media-type rj45
end
R2921_MMP#sh int gi0/1
GigabitEthernet0/1 is down, line protocol is down
  Hardware is CN Gigabit Ethernet, address is e4d3.f17c.82c1 (bia e4d3.f17c.82c1)
  Internet address is 10.90.10.2/30
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full Duplex, 100Mbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 20 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
R2921_MMP#sh controllers gi0/1
Interface GigabitEthernet0/1
= Hardware =
Hardware is PLATFORM SGMII INTERFACE
HWIDB: 2AACCDC8, INSTANCE: 2AACDB00, FASTSEND: 21191E24, MCI_INDEX: 0
Route Cache Flag: 11
= Media  RJ45 =
Media Change Count: 0
PORT IPD Registers:
        BP_PAGE_CNT: 0x0000000000000001, BP_CNTS_PRX: 0x0000000000000000
GMX Registers:
        RXX_INT_REG: 0x0000000000000000, RXX_INT_EN : 0x0000000000000000
        PRTX_CFG   : 0x000000000000300E, RXX_FRM_CTL: 0x0000000000000077
        RXX_FRM_CHK: 0x00000000000003BA, RXX_FRM_MIN: 0x0000000000000000
        RXX_FRM_MAX: 0x0000000000000000, RXX_JABBER : 0x0000000000002580
        RXX_DECISIO: 0x0000000000000018, RXX_FRM_CTL: 0x0000000000000077
        RXX_FRM_CHK: 0x00000000000003BA, RXX_JABBER : 0x0000000000002580
        RXX_DECISIO: 0x0000000000000018, RXX_UDD_SKI: 0x0000000000000000
        RXX_STATS_C: 0x0000000000000000, RXX_IFG    : 0x0000000000000008
        RXX_PAU_DRP: 0x0000000000000000, RXX_STATS_P: 0x0000000000000000
        RXX_STAT_CT: 0x0000000000000000, RXX_STATS_D: 0x0000000000000000
        RXX_STAT_DR: 0x0000000000000000, RXX_STATS_B: 0x0000000000000000
        SMACX      : 0x0000E4D3F17C82C1
        TXX_SGMII_C: 0x0000000000000001, TXX_CTL    : 0x0000000000000003
        RX_PRTS    : 0x0000000000000004, RX_BP_DROP : 0x0000000000000002
        RX_BP_ON   : 0x0000000000000040, RX_BP_OFF  : 0x0000000000000010
        TXX_PAU_PKT: 0x0000000000000060, TXX_MIN_PKT: 0x000000000000003B
        TXX_PAU_PKI: 0x0000000000000010, TXX_SOFTPAU: 0x0000000000000000
        TXX_PAU_TGO: 0x0000000000000000, TXX_PAU_ZRO: 0x0000000000000001
        INF_MODE   : 0x0000000000000022, TX_PRTS    : 0x0000000000000004
        TX_IFG     : 0x0000000000000048, TX_JAM     : 0x00000000000000EE
        TX_COL_ATMP: 0x0000000000000010, TX_PAU_DMAC: 0x00000180C2000001
        TX_PAU_TYPE: 0x0000000000008808, TX_OVR_BP  : 0x0000000000000F0F
        TX_BP      : 0x0000000000000000, TX_CORRUPT : 0x000000000000000F
        RX_PRT_INFO: 0x0000000000000000, GMX_STAT_BP: 0x0000000000000000
        TX_INT_REG : 0x0000000000000000, TX_INT_EN  : 0x0000000000000000
        ADR_CAM0   : 0x00000000000000E4
        ADR_CAM1   : 0x00000000000000D3
        ADR_CAM2   : 0x00000000000000F1
        ADR_CAM3   : 0x000000000000007C
        ADR_CAM4   : 0x0000000000000082
        ADR_CAM5   : 0x00000000000000C1
        ADR_CTL    : 0x000000000000000D, CAM_EN     : 0x00000000000000FF
        TXX_STAT0  : 0x0000000000000000, TXX_STAT1  : 0x0000000000000000
        TXX_STAT2  : 0x0000000000000000, TXX_STAT3  : 0x0000000000000000
        TXX_STAT4  : 0x0000000000000000, TXX_STAT5  : 0x0000000000000000
        TXX_STAT6  : 0x0000000000000000, TXX_STAT7  : 0x0000000000000000
        TXX_STAT8  : 0x0000000000000000, TXX_STAT9  : 0x0000000000000000
PCS Registers:
        MRX_CTL_REG: 0x0000000000001140, MRX_STS_REG: 0x0000000000000178
        RXX_STA_REG: 0x00000000000008C7, RXX_SYN_REG: 0x0000000000000003
        TXX_STA_REG: 0x0000000000000064, SGMX_AN_ADV: 0x0000000000001801
        SGMX_AN_ADV: 0x0000000000005801, MISC_CTL   : 0x0000000000000000
        ANX_ADV_REG: 0x0000000000000060, ANX_LP_ABIL: 0x0000000000005000
        ANX_RESULTS: 0x0000000000000017, ANX_EXT_ST : 0x000000000000C000
        LNX_TMR_CNT: 0x000000000000047C, TX_RXX_PLRT: 0x0000000000000000
        INT_REG    : 0x0000000000000000, INT_EN_REG : 0x0000000000000000
        LOG_ANL_REG: 0x0000000000000000, ANX_ADV_REG: 0x0000000000000060
        ANX_LP_ABIL: 0x0000000000005000, ANX_RSL_REG: 0x0000000000000017
        ANX_EXT_ST : 0x000000000000C000, LNX_TMR_CNT: 0x000000000000047C
        MISCX_CTL: 0x0000000000001801
==============PIP Statistics================
        PIP_RX_NO_ERR = 0, PIP_PARTIAL_ERR = 0
        PIP_JABBER_ERR = 0, PIP_OVER_FCS_ERR = 0
        PIP_OVER_ERR = 0, PIP_ALIGN_ERR = 0
        PIP_UNDER_FCS_ERR = 0, PIP_GMX_FCS_ERR = 0
        PIP_UNDER_ERR = 0, PIP_EXTEND_ERR = 0
        PIP_LENGTH_ERR = 0, PIP_DAT_ERR = 0
        PIP_SKIP_ERR = 0, PIP_NIBBLE_ERR = 0
        PIP_UNKNOWN_ERR_14 = 0, PIP_UNKNOWN_ERR_15 = 0
        PIP_PIP_FCS = 0, PIP_PIP_SKIP_ERR = 0
        PIP_PIP_L2_MAL_HDR = 0
        pip_rx_no_particle = 0, pip_undef_err = 0
        pip_rx_no_buf_start = 0
PHY REGISTERS:
        Display for CRC check for page:6
        PACKET_GENERATION reg_addr: 16: 0x0010
        CRC COUNTERS reg_addr: 17: 0x0000
        page number:0
        Copper Contrl @ reg_addr: 0: 0x2100
        Copper Status @ reg_addr: 1: 0x7949
        PHY Idf1 @ reg_addr: 2: 0x0141
        PHY Idf2 @ reg_addr: 3: 0x0C97
        Autoneg Adv @ reg_addr: 4: 0x0D81
        Autoneg Lnk Ptr abty @ reg_addr: 5: 0x0000
        Autoneg Exp @ reg_addr: 6: 0x0004
        Autoneg Nx Pg Tx @ reg_addr: 7: 0x2801
        Autoneg Lk Prt Nx Pg @ reg_addr: 8: 0x0000
        1000B-T Ctr @ reg_addr: 9: 0x0C00
        1000B-T St @ reg_addr: 10: 0x0000
        Copper Ext St @ reg_addr: 15: 0x3000
        Copper Specific Ctl1 @ reg_addr: 16: 0x6060
        Copper Specific St1 @ reg_addr: 17: 0x6840
        Copper Interrupt En @ reg_addr: 18: 0x0000
        Copper Specific St2 @ reg_addr: 19: 0x0040
        Copper Rcv Er Ctr @ reg_addr: 21: 0x0000
        Copper Specific Ctl2 @  reg_addr: 26: 0x8040
        page number:1
        Fiber Contrl @ reg_addr: 0: 0x1140
        Fiber Status @ reg_addr: 1: 0x7949
        Autoneg Adv @ reg_addr: 4: 0x01A0
        Autoneg Nx Pg Tx @ reg_addr: 7: 0x2001
        Fiber Ext St @ reg_addr: 15: 0x3000
        Fiber Specific Ctl1 @ reg_addr: 16: 0x0200
        Fiber Specific St1 @ reg_addr: 17: 0x0010
        Fiber Interrupt En @ reg_addr: 18: 0x0000
        Fiber Specific St2 @ reg_addr: 19: 0x0000
        Fiber Rcv Er Ctr @ reg_addr: 21: 0x0000
        Fiber Specific Ctl2 @  reg_addr: 26: 0x8085
        page number:2
        MAC Contrl @ reg_addr: 0: 0x1040
        MAC Specific Ctl1 @ reg_addr: 16: 0x0A88
        MAC Specific St1 @ reg_addr: 17: 0x0440
        MAC Interrupt En @ reg_addr: 18: 0x0000
        MAC Specific St2 @ reg_addr: 19: 0x0000
        MAC Specific Ctl2 @  reg_addr: 26: 0x0005
TX_COUNT: 0, TX_LIMITED: 0, TX_HEAD: 0, TX_TAIL: 0
TX_MIN_SIZE: 32, TX_MAX_SIZE: 512, TX_CURRENT_SIZE: 128
RX STARVES: 0
Software MAC Address Filter (hash:length/addr/mask/hits)
  0x000:  0  ffff.ffff.ffff  0000.0000.0000         0
  0x030:  0  e4d3.f17c.82c1  0000.0000.0000         0
  0x0C0:  0  0100.0ccc.cccc  0000.0000.0000         0
  0x0C0:  1  0180.c200.0002  0000.0000.0000         0
  0x0C5:  0  0180.c200.0007  0000.0000.0000         0
  Software filtered frames: 0
  Unicast overflow mode: 0
  Multicast overflow mode: 1
  Promiscuous mode: 0
  Total Number of CAM entries: 1
Port Stopped: Y
Internal Loopback Set: N
R2921_MMP#
tobyarnett
Let's start at basics. Have you tried a new cable, also have you tried a cross over? Next your speed is manually set to 100/Full. Try to use an auto/auto config. Finally can you put a laptop on that link and get a physical link coming from the MPLS switch to see if you get a link on the laptop (to rule out cabling).
Toby
Sent from Cisco Technical Support Android App
-Toby
Please don't forget to rate any helpful post.
_____________________________________
There are no great limits to growth because there are no limits of human intelligence, imagination, and wonder.
- Ronald Reagan
8 Replies 8
umesh.chowdhary
IOS version on the router
R2921_MMP#sh ver | i image
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M4.bin"
Hello Umesh
Try with default configuration:
(config)#default interface gi0/1
Try clear interface
#clear interface gi0/1
Try another interface on router, f.e. gi0/0 if it will come UP/UP.
Try this interface connect to another router/switch if it is working.
Best Regards
Please rate helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
tobyarnett
Toby
-Toby
- Ronald Reagan
Hi Toby ,
Thanks for quick response.
I treid connecting my laptop directly to the MPLS link and I was able to ping the other end. I also tried this link connecting to other switch and interaface f the siwtch came up...I also tried couple of cable but no luck bfringing the router port UP.
I also tried using auto/auto setting for speed/duplex on the port with no joy.....
Toby ,
By mistake I clicked on "Correct Answer" TAB on your post , can you please delete your post (and repost) as the query still unanswered.
tobyarnett
I can't seem to delete on my tablet. I will try from my PC soon.
If your link is coming up on the laptop and you can ping to the other end then there is an issue with your router vs the ISP. You have media type rj45in on the config. Do you have a gbic in that port? If so have you tried a different gbic?
-Toby
- Ronald Reagan
Toby ,
I don't have SFP in my router interface as its a normal Gig Port and Router modem is Cisco 2921.
It seems something to do with Port on Router. Please see highlighted part  "Show Controller Gi0/1" output .
check the port with laptop as Toby told you
