Packet loss
musthafa786
I am getting packet loss when I do continuous ping to below two destination,
Could anyone help me on this ?   thanks.
dest 1:
64 bytes from 100.50.23.140: icmp_seq=115 ttl=61 time=4.742 ms
64 bytes from 100.50.23.140: icmp_seq=116 ttl=61 time=3.879 ms
64 bytes from 100.50.23.140: icmp_seq=117 ttl=61 time=3.625 ms
64 bytes from 100.50.23.140: icmp_seq=118 ttl=61 time=3.648 ms
64 bytes from 100.50.23.140: icmp_seq=119 ttl=61 time=3.856 ms
64 bytes from 100.50.23.140: icmp_seq=120 ttl=61 time=3.791 ms
Request timeout for icmp_seq 121
64 bytes from 100.50.23.140: icmp_seq=122 ttl=61 time=3.595 ms
64 bytes from 100.50.23.140: icmp_seq=123 ttl=61 time=3.717 ms
64 bytes from 100.50.23.140: icmp_seq=124 ttl=61 time=3.568 ms
64 bytes from 100.50.23.140: icmp_seq=152 ttl=61 time=3.711 ms
64 bytes from 100.50.23.140: icmp_seq=153 ttl=61 time=3.819 ms
64 bytes from 100.50.23.140: icmp_seq=154 ttl=61 time=3.484 ms
64 bytes from 100.50.23.140: icmp_seq=155 ttl=61 time=3.766 ms
64 bytes from 100.50.23.140: icmp_seq=156 ttl=61 time=3.797 ms
64 bytes from 100.50.23.140: icmp_seq=157 ttl=61 time=3.799 ms
64 bytes from 100.50.23.140: icmp_seq=158 ttl=61 time=3.828 ms
64 bytes from 100.50.23.140: icmp_seq=159 ttl=61 time=3.754 ms
64 bytes from 100.50.23.140: icmp_seq=160 ttl=61 time=3.711 ms
64 bytes from 100.50.23.140: icmp_seq=153 ttl=61 time=8003.554 ms (DUP!)
Request timeout for icmp_seq 161
64 bytes from 100.50.23.140: icmp_seq=162 ttl=61 time=3.836 ms
dest 2:
64 bytes from 100.50.33.10: icmp_seq=756 ttl=61 time=3.672 ms
64 bytes from 100.50.33.10: icmp_seq=757 ttl=61 time=2146293.864 ms
wrong data byte #8 should be 0x8 but was 0x55
cp:51 38 58 b5 80 18 16 a0
            55 ac  0  0  1  1  8  a  0  0 fd 90 14 15 16 17
           28 29 2a 2b 2c 2d 2e 2f 30 31 32 33 34 35 36 37
dp:51 37 58 b5  0  5 e1 3e
             8  9  a  b  c  d  e  f 10 11 12 13 14 15 16 17
            18 19 1a 1b 1c 1d 1e 1f 20 21 22 23 24 25 26 27
64 bytes from 100.50.33.10: icmp_seq=758 ttl=61 time=3.774 ms
64 bytes from 100.50.33.10: icmp_seq=759 ttl=61 time=3.797 ms
64 bytes from 100.50.33.10: icmp_seq=760 ttl=61 time=3.726 ms
64 bytes from 100.50.33.10: icmp_seq=761 ttl=61 time=2.932 ms
Musthafa
cflory
Are you taking errors on your circuit or is there an issue at your provider?
-Chris
The "DUP" means that "ping" received two replies to one enquiry - the
icmp_sequence number is duplicated.ing will report duplicate and  damaged  packets.   Duplicate  packets
should  never occur, and seem to be caused by inappropriate link-level
retransmissions.  Duplicates may occur  in  many  situations  and  are
rarely  (if  ever) a good sign, although the presence of low levels of
duplicates may not always be cause for alarm.
Damaged packets are obviously serious cause for alarm and often  indi-
cate  broken hardware somewhere in the ping packet’s path (in the net-
work or in the hosts).
Jawad
