CISCO 2921 Router Rebooting Automatically
saudhusain
Hi Everyone
I am facing issue on CISCO 2921 Router since last week. Router keep on rebooting automatically. Find below details of Show commands output. Appreciate if anyone can guide about the root cause of Router rebooting. There are no configuration changes perform since last week and Router was working smoothly since last 5 months.
DRIVE#show ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 11-Mar-10 00:04 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
DRIVE uptime is 3 hours, 51 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.150-1.M2.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID
3 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2921/K9
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc None None None
data None None None
DRIVE# dir flash:
Directory of flash0:/
2 -rw- 2903 May 24 2010 14:01:22 +00:00 cpconfig-29xx.cfg
3 -rw- 2915328 May 24 2010 14:01:36 +00:00 cpexpress.tar
4 -rw- 1038 May 24 2010 14:01:44 +00:00 home.shtml
5 -rw- 115712 May 24 2010 14:01:50 +00:00 home.tar
6 -rw- 1697952 May 24 2010 14:02:06 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
7 -rw- 415956 May 24 2010 14:02:18 +00:00 sslclient-win-1.1.4.176.pkg
10 -rw- 4615 Jul 12 2010 21:09:42 +00:00 archived-config-0
11 -rw- 4652 Jul 13 2010 11:52:10 +00:00 archived-config-1
12 -rw- 4404 Jul 13 2010 17:41:08 +00:00 archived-config-2
13 -rw- 4428 Jul 13 2010 19:52:46 +00:00 archived-config-3
14 -rw- 4462 Jul 13 2010 19:54:34 +00:00 archived-config-4
15 -rw- 4080 Jul 13 2010 20:13:22 +00:00 archived-config-5
16 -rw- 4147 Mar 24 2011 14:03:14 +00:00 archived-config-6
17 -rw- 4008 Mar 24 2011 21:30:00 +00:00 archived-config-7
18 -rw- 3986 Sep 19 2011 19:58:40 +00:00 archived-config-8
19 -rw- 4095 Sep 11 2014 20:47:38 +00:00 archived-config-9
20 -rw- 4095 Sep 11 2014 20:48:46 +00:00 archived-config-10
DRIVE#show logging
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 23 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 23 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
Trap logging: level informational, 27 message lines logged
Log Buffer (8192 bytes):
*Mar 1 00:00:03.843: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2900 Next reboot level = ipbasek9 and License = ipbasek9
*Sep 15 08:06:46.811: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
*Sep 15 08:06:46.811: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Sep 15 08:06:46.811: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
*Sep 15 08:06:47.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
*Sep 15 08:06:47.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Sep 15 08:06:47.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to up
*Sep 15 08:06:49.999: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to down
*Sep 15 08:06:50.079: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
*Sep 15 08:06:51.111: %LINK-5-CHANGED: Interface Tunnel3, changed state to administratively down
*Sep 15 08:06:53.223: %SYS-5-CONFIG_I: Configured from memory by console
*Sep 15 08:06:55.727: %SYS-5-RESTART: System restarted --
*Sep 15 08:06:55.895: %SNMP-5-COLDSTART: SNMP agent on host DRIVE is undergoing a cold start
*Sep 15 08:06:58.171: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to up
*Sep 15 08:07:15.807: %TRACKING-5-STATE: 8 ip sla 1 reachability Down->Up
7 Replies 7
balaji.bandi
At this stage hard to stay what is causing this auto reboot, since it says device come up with Power-on
here are steps to identify the issue.
1. check any Power Lead loose connection.
2. connect console and capture the logs when this situation happens again to identify what causing the issue.
3. you can try upgrading to a newer version and see if that fix the issue.
BB
Martin L
show envi all ---look for temp, fans ok? how is Comm room?
any evidence of attacks to overflow /overload router? is traffic/bandwidth ok ?
There all around 5-6 CISCO devices in same data center and all are working fine. All devices are getting power from same source. how to identify if there is any attach on Router.
DRIVE#show environment all
SYSTEM POWER SUPPLY STATUS
Internal Power Supply Type: AC
Internal Power Supply 12V Output Status: Normal
External Redundant Power Supply is absent or powered off
SYSTEM FAN STATUS
Fan 1 OK, Low speed setting
Fan 2 OK, Low speed setting
Fan 3 OK, Low speed setting
Fan 4 OK, Low speed setting
SYSTEM TEMPERATURE STATUS
Intake Left temperature: 18 Celsius, Normal
Intake Right temperature: 17 Celsius, Normal
Exhaust Left temperature: 28 Celsius, Normal
Exhaust Right temperature: 22 Celsius, Normal
CPU temperature: 72 Celsius, Normal
Power Supply Unit temperature: 39 Celsius, Normal
REAL TIME CLOCK BATTERY STATUS
Battery OK (checked at power up)
SYSTEM POWER
Motherboard Components Power consumption = 58.8 W
Total System Power consumption is: 58.8 W
Environmental information last updated 00:00:07 ago
DRIVE#show processes cpu history
DRIVE 03:40:03 PM Sunday Sep 15 2019 UTC
111222221111111111111111111111111111111111111111222221111111
100
90
80
70
60
50
40
30
20
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
222222324222222122122222222112122222222222212222212222222222
100
90
80
70
60
50
40
30
20
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
2 1 1
3123124
100
90
80
70
60
50
40
30
20 *
10 * * *
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
CPU utilization for five seconds: 1%/0%; one minute: 1%; five minutes: 1%
Looks for me all good as of now..maybe worth connect console cable and capture the logs.
BB
Hello
Check the flash, bootflash or sup-bootflash: for any crashinfo files, You then should be able to read these files and find possible find a root cause for the reloads.
dir flash:
dir bootflash
more flash:crashinfo_xxxx
more bootflash:crashinfo_xxxx
Kind Regards
Paul
upgrading CISCO IOS resolve the issue . Thanks you all for your reply and support.
Hi Saudhusain,
Can i know the firmware version which you have updated.
