Cisco 2921 SM-D-ES3-48-P Session Hang. BAUD rate issues.
I have a problem of my own making. This ES module previously had no OS loaded and was permanently in rommon. I was able to get an image on via xmodem. To speed up the process I had the console line set to 115200 BAUD on the router. In my excitement, after verifying the image was in the flash, I set the BAUD parameter back to 9600 on the ES module. (my understanding is the ES modules function at 115200). Things quickly got hosed after that. Now, when I try to session back into the module, it just permanently hangs.
So, when I session I get below:
Router#service-module gi1/0 sess
Trying 192.168.1.1, 2067 ... Open
And there's nothing after that. Normally, you hit enter a couple times and it kicks it into Switch> but, like I said, the prompt just freezes and I never get into the actual switch. I can break back into the router and disconnect the open session. service-module status shows it's up and in Steady state.
service-module interface slot/port password-reset does not work. I see the interface state changes and I get the message about password reset process being complete but I still can't get into the switch. I was really hoping password-reset would force it back into rommon but with the speed set to what it is I'm afraid I'll never be able to get back into the ES module.
Edit: I'd still be curious about if there's a way to fix this but I just got told to ship the module back to our warehouse so the problem is a moot point now. Apologizes for taking up anyone's time.
balaji.bandi
Looks like it hanged, may be need to remove the slot and putback to get back normal, or reload whole device.(reboot)
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/eesm_sw.html
BB
