Cisco 2921 with Telekom Malaysia
billen1311
Good evening,
we are wokring on a project for a company with an office in Kuala Lumpur. The office currently has a VDSL circuit with Telekom Malaysia which has also provided them with a VDSL modem. I've been told that Telekom Malaysia is tagging the traffic and is using VLAN500 to do so. We have decided to use Cisco 2921 for our network, connect it to the VDSL modem and setup VLAN tagging for VLAN500 on the WAN interface of the Cisco but some of our consultants disagree that this will work.
My question is; has anyone ever dealt with configuring a Cisco device for a Malaysian ISP and if so, can what I am suggesting be done?
Our contact in Malaysia has specified that the router should have an Ethernet WAN interface, VLAN tagging capabilities on the WAN interface and be configured with a PPPoE MTU1492.
Thank you
johnlloyd_13
Level 9
Level 9
We have several MetroEs and E1s with TM. I'm not sure if we've had any DSL circuit with them.
I would agree with what your consultant has suggested and IMHO an 2921 could be an overkill (given the right WIC). Why not look at an 800 ISR?
http://www.cisco.com/en/US/products/ps11063/index.html
Thank you for your reply!
2921 was chosen becase we're also setting up a VPN tunnel, VoIP and a couple more services on the same router (firewall as well). Also, we decided to get a very powerful device now to accommodate any potential future growth.
My concern is whether Cisco routers can do what the cheap Telekom Malaysia routers do in terms of tagging/untagging packets or not?
Thank you
The term 'tagging' is a switch function. Maybe you should be looking at a multilayer switch to achieve your goal?
